- What's New
- User Guide
- Template Reference
API Reference
- Before You Start
API
- Calling APIs
Stacks
- Listing Events of a Stack
- Obtaining Stack Metadata
- Listing Stacks
- Creating a Stack
- Obtaining a Stack Template
- Listing Stack Resources
- Listing Stack Outputs
- Continuing to Deploy a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Deleting a Stack with Conditions
- Continuing to Roll Back a Stack
- Execution Plans
- Template Analysis
- Template Management
Stack Sets
- Listing Stack Sets
- Creating a Stack Set
- Obtaining a Stack Set Template
- Listing Stack Set Operations
- Obtaining Metadata of a Stack Set
- Listing Stack Instances
- Creating Stack Instances
- Deleting Stack Instance Deprecated
- Updating Stack Instances
- Deleting Stack Instances
- Deploying a Stack Set
- Deleting a Stack Set
- Updating a Stack Set
- Obtaining Metadata of a Stack Set Operation
- Obtaining a Stack Instance
- Customized Providers
- Resource Formation - Hook
- Resource Formation - Module Management
- Appendix
- Change History
- FAQs
- Videos
More Documents
- Getting Started
- Stack Management
- CTS
Template Reference
- Template Introduction
List of Elements
- Resource Indexes
- AOS.Stack
- CCE.Addon.AutoScaler
- CCE.Cluster
- CCE.HelmRelease
- CCE.NodePool
- CCE.Pod
- CCE.Storage.OBS
- CCE.Storage.SFS
- DCS.Redis
- ECS.CloudServer
- ECS.KeyPair
- NAT.Instance
- NAT.SNatRule
- OBS.Bucket
- RDS.MySQL
- SFS.FileSystem
- ULB.Healthmonitor
- ULB.Listener
- ULB.LoadBalancer
- ULB.Member
- ULB.Pool
- VPC.EIP
- VPC.SecurityGroup
- VPC.SecurityGroupRule
- VPC.Subnet
- VPC.VPC
Data Structure
- AOS.BatchItem
- Basic.KeyValuePair
- Basic.Label
- Basic.LabelSelector
- Basic.NameAndSecretValue
- Basic.NameKeyPair
- Basic.NameValuePair
- CCE.Addon.AutoScaler.Node
- CCE.DataVolume
- CCE.HelmChart
- CCE.Labels
- CCE.NodePool
- CCE.PublicIP
- DCS.InstanceBackupPolicy
- DCS.PeriodicalBackupPlan
- ECS.DataVolume
- ECS.EIP
- ECS.ExtendParam
- ECS.MountedVolumes
- ECS.NICS
- ECS.Personality
- ECS.PublicIP
- ECS.RootVolume
- ECS.SecurityGroup
- ECS.ServerTags
- ECS.VolumeExtendParam
- K8S.PodSecurityContext
- K8S.SecurityContext.SeLinuxOptions
- MySQL.DBUser
- MySQL.DataBase
- MySQL.DataStore
- RDS.BackupStrategy
- RDS.HA.Mysql
- RDS.Volume
- ULB.StickySession
- VPC.BandWidth
- VPC.PublicIP
- Appendix
- FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
API
- Creating a Template
- Querying a Template List
- Updating a Template
- Deleting a Template
- Downloading a Template
- Querying the Input Parameters of a Template
- Creating a Stack
- Deleting a Stack
- Executing a Stack Lifecycle
- Querying a Stack List
- Querying a Stack
- Querying a Stack Element List
- Querying a Stack Output
- Querying Stack Input
- Querying the Execution Record of a Stack
- Querying a Stack Execution Record List
- Appendix
- Change History
- Before You Start
API
- Calling APIs
Stacks
- Listing Stacks
- Creating a Stack
- Deploying a Stack
- Deleting a Stack
- Updating a Stack
- Execution Plans
- Template Analysis
Stack Sets
- Appendix
- Change History
- User Guide (Kuala Lumpur Region)
Element Description
CCE.Addon.AutoScaler is a plug-in for node auto-scaling in a K8S cluster.
Element Properties
Property |
Mandatory |
Descripiton |
scaleDownUtilizationThreshold |
No |
Node resource usage ratio Type: float Value Description: The value ranges from 0 to 1. Default: 0.4 Value Constraint: The value ranges from 0 to 1. Suggestion: Set this parameter based on the live environment. |
clusterId |
Yes |
ID of the cluster to which the resource belongs Type: Cloud.CCE.Cluster.Id Value Description: Indicates the ID of an existing or new container cluster. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID. |
scaleDownEnabled |
Yes |
Scale down function switch Type: boolean Default: False |
publicKey |
No |
Public key. This parameter is mandatory if the stack is billed in the yearly/monthly mode. Type: Cloud.ECS.KeyPair.PublicKey |
nodePasswd |
No |
Password of the scaled node root user Type: password |
nodes |
Yes |
AZs, specifications, OSs, and taints of the scaled nodes Type: CCE.Addon.AutoScaler.Node array Suggestion: In node scaling, taints are an array consisting of key, value, and effect. The effect can be set to NoSchedule, PreferNoSchedule, or NoExecute. |
sshKeyName |
No |
Node key pair Type: Cloud.ECS.KeyPair.Name |
scaleDownUnneededTime |
No |
When a node remains idle for this specified time duration (in minutes), scaling down will be performed. Type: integer Value Description: The value ranges from 1 to 1000. Default: 10 Value Constraint: The value ranges from 1 to 1000. Suggestion: Set this parameter based on the live environment. |
Relationships Between Elements
Description |
Target |
Dependency |
Inclusion |
Return Value
Property |
Type |
Description |
clusterId |
string |
ID of the cluster which is associated with the AutoScaler |
refName |
string |
Name of the AutoScaler |
refID |
string |
UID of the AutoScaler |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0 inputs: clusterId: default: "e0f98d46-9716-11e8-a25f-0255ac106314" description: cluster ID. nodePasswd: default: "******" description: node root user password scaleDownEnabled: default: true description: scale down enabled. scaleDownUnneededTime: default: 10 description: sale down unneeded time scaleDownUtilizationThreshold: default: 0.5 description: scale down utilization threshold avaliableZone: default: az1.dc1 description: avaliableZone. nodeFlavor: default: s1.xlarge description: node flavor. nodeOS: default: EulerOS 2.2 description: node OS. node_templates: autoscaler: type: Cloud.CCE.Addon.AutoScaler properties: clusterId: get_input: clusterId nodePasswd: get_input: nodePasswd scaleDownEnabled: get_input: scaleDownEnabled scaleDownUnneededTime: get_input: scaleDownUnneededTime scaleDownUtilizationThreshold: get_input: scaleDownUtilizationThreshold nodes: - az: get_input: avaliableZone flavor: get_input: nodeFlavor os: get_input: nodeOS outputs: autoscaler_id: value: {get_attribute: [autoscaler, refID]}
