Managing Subnet Tags
- Add a tag to a subnet.
- Modify a subnet tag.
- Delete a subnet tag.
If you have configured tag policies for subnets, you need to add tags to your subnets based on the tag policies. If you add a tag that does not comply with the tag policies, subnets may fail to be created. Contact the administrator to learn more about tag policies.
| Parameter | Requirements | Example Value |
| Key |
| subnet_key1 |
| Value |
| subnet-01 |
Notes and Constraints
Each cloud resource can have a maximum of 20 tags.
Editing Tags of a Single Resource
- Go to the subnet list page.
- In the subnet list, locate the target subnet and click its name.
- On the Tags tab, click Edit Tag in the upper left corner above the tag list.
The Edit Tag dialog box is displayed.
- Perform the following operations on the tags as required:
- Adding a tag: Click
, enter a tag key and value, and click OK. - Modifying a tag: Click
next to the target tag key or value to delete the original value, enter a new value, and click OK. - Deleting a tag: Click Delete next to the target tag and click OK.
