Managing VPC Tags
- Add tags to a VPC.
- Modify a VPC tag.
- Delete a VPC tag.
If your organization has configured tag policies for VPCs, you need to add tags to your VPCs based on the policies. If you add a tag that does not comply with the tag policies, the VPC may fail to be created. Contact the administrator to learn more about tag policies.
For details about VPC tag requirements, see Table 1.
| Parameter | Requirements | Example Value |
| Key |
| vpc_key1 |
| Value |
| vpc-01 |
Notes and Constraints
Each cloud resource can have a maximum of 20 tags.
Editing Tags of a Single Resource
- Go to the VPC list page.
- In the VPC list, locate the target VPC and click its name.
- On the Tags tab, click Edit Tag in the upper left corner above the tag list.
The Edit Tag dialog box is displayed.
- Perform the following operations on the tags as required:
- Adding a tag: Click
, enter a tag key and value, and click OK. - Modifying a tag: Click
next to the target tag key or value to delete the original value, enter a new value, and click OK. - Deleting a tag: Click Delete next to the target tag and click OK.
Editing Tags of Multiple Resources in Batches
- In the VPC list, select the target VPCs and click Edit Tag in the upper left corner above the VPC list.
The Edit Tag page is displayed.
