Help Center/ Virtual Private Cloud/ User Guide/ Traffic Mirroring/ Mirror Sessions/ Modifying the Basic Information About a Mirror Session
Updated on 2026-10-30 GMT+08:00
You can modify the basic information about a mirror session, including its name and description.
  1. Go to the mirror session list page.
  2. In the mirror session list, locate the row that contains the mirror session and click Modify in the Operation column.
    The Modify Mirror Session dialog box is displayed.
  3. Modify the parameters as prompted.
    Table 1 Parameters that can be modified
    Example Value
    Name
    Mandatory
    Enter a different name for the mirror session. The name:
    • Can contain 1 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    mirror-session-01
    Optional
    Enter a description for the mirror session in the text box as required.
  4. Click OK to save the modification.
