Changing the Mirror Filter for a Mirror Session
A mirror session can be associated with only one mirror filter. If the current mirror filter cannot meet your requirements, you can change one.
- Go to the mirror session list page.
- In the mirror session list, locate the row that contains the mirror session and choose More > Change Mirror Filter in the Operation column.
The Change Mirror Filter dialog box is displayed.
- In the mirror filter list, select a mirror filter and click OK.
After the change, you can see the new mirror filter in the Mirror Filter column of the mirror session list.
If there is no mirror filter you want, create one by referring to Creating a Mirror Filter.
