Associating Mirror Sources with a Mirror Session
You can associate mirror sources with a mirror session.
When associating mirror sources with a mirror session, learn about the constraints on mirror sources in Table 5.
- Go to the mirror session list page.
- In the mirror session list, locate the row that contains the mirror session and click its name with a hyperlink.
- Click the Mirror Sources tab. In the upper left corner of the mirror source list, click Associate.
The Associate Mirror Sources dialog box is displayed.
- In the mirror source list, select mirror sources and click OK.
In the mirror source list, you can view the associated mirror sources.
