Help Center/ Virtual Private Cloud/ User Guide/ Traffic Mirroring/ Mirror Sessions/ Enabling or Disabling a Mirror Session
Updated on 2025-04-23 GMT+08:00
You can enable or disable a mirror session.
- If the mirror session is disabled, traffic of mirror sources cannot be monitored.
- If the mirror session is enabled, traffic of mirror sources can be monitored.
- Go to the mirror session list page.
- In the mirror session list, locate the row that contains the mirror session and click Enable or Disable in the Operation column.
A confirmation dialog box is displayed.
- Click OK.
