Help Center/ Virtual Private Cloud/ User Guide/ Traffic Mirroring/ Mirror Filters/ Modifying the Basic Information About a Mirror Filter
Updated on 2025-04-23 GMT+08:00
You can modify basic information about a mirror filter, including its name and description.
- Go to the mirror filter list page.
- Locate the target mirror filter and click its name.
- Click the Basic Information tab and modify parameters as prompted.
- Click
next to the parameter to be modified and enter information in the text box. - Click
to save the modification.
Table 1 Parameters that can be modified Parameter
Example Value
Name
Mandatory
Enter a different name for the mirror filter. The name:- Can contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
mirror-filter-01
Optional
Enter a description for the mirror filter in the text box as required.
- Click
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
