Adding an Inbound or Outbound Mirror Filter Rule
You can add inbound and outbound rules to a mirror filter.
- Inbound rules match the traffic received by a mirror source.
- Outbound rules match the traffic sent by a mirror source.
Mirror Filter Rule Examples
| Direction | Priority | Protocol | Action | Type | Source | Source Port Range | Destination | Destination Port Range | Filtering Description |
| Inbound | 1 | TCP | Accept | IPv4 | 172.16.0.0/24 | 10000-10001 | 10.0.0.3/32 | 80-80 | If traffic enters a network interface of the mirror source, the mirror session will mirror packets that meet the following rule: TCP (IPv4) packets from source 172.16.0.0/24 over port 10000 or 10001 to destination 10.0.0.3/32 over port 80 |
| Outbound | 1 | All | Reject | IPv4 | 192.168.0.0/24 | All | 10.2.0.0/24 | All | If traffic leaves a network interface of the mirror source, the mirror session will not mirror packets that meet the following rule: IPv4 packets from source 192.168.0.0/24 over any port to destination 10.2.0.0/24 over any port. |
- Go to the mirror filter list page.
- Locate the target mirror filter and click the number in the Inbound and Outbound Rules column.
The Inbound Rules tab page is displayed.
- On the Inbound Rules tab, click Add Rule. In the displayed dialog box, set required parameters to add an inbound rule. You can click
to add more inbound rules. Table 2 Inbound rule parameter description Parameter
Example Value
Priority
Priority of a mirror filter rule.- A priority value can be from 1 to 65535. A smaller value indicates a higher priority.
- Priorities of inbound rules must be unique for each mirror filter.
A mirror filter can contain multiple rules and the rules are matched in ascending order of priority.
For details, see the matching process of mirror filter rules.
Protocol
Select a network protocol.- If you select TCP, you can customize the source and destination port ranges.
- If you select UDP, you can customize the source and destination port ranges.
- If you set Type to IPv4 and select ICMP, all ports are specified for source and destination port ranges by default.
- If you set Type to IPv6 and select ICMPv6, all ports are specified for source and destination port ranges by default.
- If you select All, all network protocols are supported and all ports are specified for source and destination port ranges by default.
TCP
Action
Whether to accept or reject inbound traffic of a mirror source.- If you set Action to Accept, the traffic will be mirrored to the mirror target.
- If you set Action to Reject, the traffic will not be mirrored to the mirror target.
Accept
Type
IP address version of inbound traffic. You can specify:- IPv4
- IPv6
IPv4
Source
Source of inbound traffic. You can enter:- A single IP address: IP address/mask
Example IPv4 address: 192.168.10.10/32
Example IPv6 address: 2002:50::44/128
- An IP address range in CIDR notation: IP address/mask
Example IPv4 address range: 192.168.52.0/24
Example IPv6 address range: 2407:c080:802:469::/64
- All IP addresses
0.0.0.0/0 represents all IPv4 addresses.
::/0 represents all IPv6 addresses.
10.0.0.0/24
Source Port Range
Source port range of inbound traffic.- Port range: 1 to 65535
- Use a hyphen (-) to connect the start port and the end port, for example, 22-23. The end port cannot be smaller than the start port.
- If not specified or 1-65535 is specified, all ports are used.
22-23
Destination
Destination of inbound traffic. You can enter:- A single IP address: IP address/mask
- All IP addresses
0.0.0.0/0
Destination port range of inbound traffic.- Port range: 1 to 65535
1-65535
Enter the description of the mirror filter rule in the text box as required.
- Click OK.
You can view the added inbound rule in the list.
- Click the Outbound Rules tab. In the upper left corner of the outbound rule list, click Add Rule to add an outbound rule. You can click
to add more outbound rules. Table 3 Outbound rule parameter description Parameter
Example Value
Priority
Protocol
All
Action
Whether to accept or reject outbound traffic of a mirror source.- If you set Action to Accept, the traffic will be mirrored to the mirror target.
Reject
Type
IP address version of outbound traffic. You can specify:- IPv4
- IPv6
IPv4
Source
Source of outbound traffic. You can enter:- A single IP address: IP address/mask
- All IP addresses
192.168.0.0/24
Source Port Range
Source port range of outbound traffic.
All
Destination
Destination of outbound traffic. You can enter:- A single IP address: IP address/mask
- All IP addresses
10.2.0.0/24
Destination port range of outbound traffic.- Port range: 1 to 65535
All
- Click OK.
You can view the added outbound rule in the list.
