Updated on 2026-11-24 GMT+08:00
Constraints of PFS
Operations
- An existing OBS bucket cannot be changed to a parallel file system. For details about how to create a parallel file system, see Creating a Parallel File System.
- Custom domain names of parallel file systems cannot be configured on OBS Console. You can configure them using APIs by referring to Configuring a Custom Domain Name.
Functions
- Image processing cannot be used to process (such as slim, resize, or watermark) images stored in parallel file systems.
- Cross-region replication is not supported.
- Versioning is not supported.
- Bucket inventory is not supported.
- Static website hosting is not supported.
- Configuration of default storage class for a parallel file system is not supported.
- A parallel file system can be mounted to multiple Linux servers for concurrent reads, but this is not recommended for concurrent writes.
- Server-side encryption for parallel file systems has the following constraints:
- Only SSE-KMS is supported, and the bucket key must be enabled. (For parallel file systems, the bucket key is also called the parallel file system key.)
- Encrypting files during upload with encryption headers is not supported. Such headers include x-obs-server-side-encryption, x-obs-server-side-data-encryption, and x-obs-server-side-encryption-kms-key-id. By default, uploaded files inherit the encryption settings of the parallel file system.
- Changes to the server-side encryption settings of a parallel file system take about three seconds to take effect.
Performance
- A parallel file system provides a maximum bandwidth of 16 Mbit/s per TB by default.
Naming
- In a parallel file system, a file name cannot contain two consecutive slashes (//). For example, if you name a file as test//123.txt, an error will be reported.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
