Updated on 2026-11-24 GMT+08:00
Checking the Upload Progress
In large-file or batch upload scenarios, you can use OBS Console, SDKs, OBS Browser+, or obsutil to track the upload progress of a specific object in real time and estimate when the task will finish.
The methods differ as follows:
  • On OBS Console or OBS Browser+, you can check the status of the upload task to confirm whether the object was uploaded successfully.
  • OBS SDKs provide the progress listener to display a progress bar. The progress percentage tells you whether the object was uploaded successfully.
  • obsutil displays the upload progress percentage in real time. The percentage tells you whether the object was uploaded successfully.
Important Notes
If you refresh or close the browser when checking the upload progress on OBS Console, the current task is canceled and all records in the task center are cleared.
Ways to Check Upload Progress
You can check the object upload progress using OBS Console, SDKs, OBS Browser+, or obsutil, but not using APIs.
