Configuring User Permissions
If your cloud service account does not need individual IAM users, then you may skip this section. Your permissions to use OBS functions are not affected.
OBS is separately deployed from other cloud resources. If IAM users are required, you need to grant them access permissions for OBS.
Process
![](https://support.huaweicloud.com/intl/en-us/usermanual-obs/en-us_image_0170301902.png)
The below example describes how to grant an IAM user the Tenant Guest permission for OBS.
- Create a user group and assign permissions.
Create a user group on the IAM console, and assign the group the Tenant Guest permission.
- Create an IAM user and add it to the user group.
Create a user on the IAM console and add the user to the group created in 1.
- Log in and verify the permission granting.
Log in to OBS Console using the newly created user, and verify that the assigned permission has taken effect:
- Choose Object Storage Service from the service list to go to the OBS homepage. If the list of buckets is displayed and you can view the basic information about any bucket, but you cannot create or delete buckets or perform any other operations, the granted Tenant Guest permission has already taken effect.
- Go to an OBS bucket. If the list of objects is displayed and you can download objects, but you cannot upload or delete objects or perform any other operations, the Tenant Guest permission granted has already taken effect.
