Updated on 2025-12-16 GMT+08:00
OBS Custom Policies
Custom policies can be created to supplement the system-defined policies of OBS. For the actions supported for custom policies, see Bucket-Related Actions and Object-Related Actions.
You can create custom policies in either of the following two ways:
  • Visual editor: Select cloud services, actions, resources, and request conditions without the need to know policy syntax.
  • JSON: Edit JSON policies from scratch or based on an existing policy.
For details, see Creating a Custom Policy. The following provides examples of common OBS custom policies.
Example Custom Policies
  • Example 1: Grant users all OBS permissions.
    This policy allows users to perform any operation on OBS.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "obs:*:*"
  • Example 2: Grant users all permissions for OBS Console.
    This policy allows users to perform all operations on OBS Console.
    When logging in to OBS Console, users may need to access resources of other services, such as CTS audit information, CDN acceleration domain names, and KMS keys. Therefore, in addition to the OBS permissions granted in example 1, the access permissions for other services need to be granted. CDN is a global service, while CTS and KMS are regional ones. You need to configure the Tenant Guest permission for the global project and regional projects based on the services and regions that you use.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "obs:*:*"
  • Example 3: Grant users the read-only permission for all directories in a bucket.
    This policy allows users to list and download all objects in bucket obs-example.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "obs:object:GetObject",
                    "obs:bucket:ListBucket"
                "Resource": [
                    "obs:*:*:object:obs-example/*",
                    "obs:*:*:bucket:obs-example"
  • Example 4: Grant users the read-only permission for a specified directory in a bucket.
    This policy allows users to download objects in only the my-project/ directory of bucket obs-example. Objects in other directories can be listed but cannot be downloaded.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                "Resource": [
                    "obs:*:*:object:obs-example/my-project/*",
  • Example 5: Grant users the read/write permissions for a specified directory in a bucket.
    This policy allows users to list, download, upload, and delete objects in the my-project directory of bucket obs-example.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "obs:object:ListMultipartUploadParts",
                    "obs:bucket:ListBucket",
                    "obs:object:DeleteObject",
                    "obs:object:PutObject"
                "Resource": [
  • Example 6: Grant users all permissions for a bucket.
    This policy allows users to perform any operation on bucket obs-example.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "obs:*:*"
                "Resource": [
                    "obs:*:*:bucket:obs-example",
  • Example 7: Grant users the permission to deny object upload.
    A deny policy must be used together with other policies. If the permissions assigned to a user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
    If you grant the system policy OBS OperateAccess to a user but do not want the user to have the object upload permission (which is also a permission allowed by OBS OperateAccess), you can create a custom policy besides the OBS OperateAccess policy, to deny the user's upload permission. According to the authorization principle, the policy with the deny statement takes precedence. This means the user can perform all operations allowed by OBS OperateAccess except for the upload operation. The following is an example of a deny policy:
        "Version": "1.1",
        "Statement": [
                "Effect": "Deny",
                "Action": [
