Managing Global User Policies When Using Superior Scheduler
If a tenant uses a Superior scheduler, you can configure the global policy for users to use the resource scheduler, including:
- Maximum running apps
 - Maximum pending apps
 - Default queue
- Add a policy.
- On FusionInsight Manager, choose Tenant Resources.
 - Choose Dynamic Resource Plan.
 - Click the Global User Policy tab.
        defaults(default setting) indicates that the policy specified for defaults is used if a user does not have a global policy. The default policy cannot be deleted.
 - Click Create Global User Policy. In the displayed dialog box, set the following parameters:
       Figure 1 Creating a global user policy
       - Cluster: Select the target cluster.
 - Username: indicates the user for whom resource scheduling is controlled. Enter an existing username in the current cluster.
 - Max Running Apps: indicates the maximum number of tasks that the user can run in the current cluster.
 - Max Pending Apps: indicates the maximum number of tasks that the user can suspend in the current cluster.
 - Default Queue: indicates the queue of the user. Enter the name of an existing queue in the current cluster.
- Modify a policy.
 - In the row that contains the desired user policy, click Modify in the Operation column.
 - In the displayed dialog box, modify parameters and click OK.
 - Delete a policy.
 - In the row that contains the desired user policy, click Delete in the Operation column.
In the displayed dialog box, click OK.
