Updated on 2025-03-20 GMT+08:00
SQL SPLIT Functions
SPLIT functions split a character string using a delimiter, and return the substrings.
Syntax
SELECT split_to_map(x, delimiter01, delimiter02)
SPLIT Function Statements
Statement
Example
split
Splits a character string using a delimiter and returns the substrings.
split(x, delimiter,[limit])
  • x: varchar parameter value.
  • delimiter: delimiter.
  • limit: an integer greater than 0, specifying the maximum number into which the character string can be split.
split_part
Splits a character string using a specified delimiter and returns the indexed content.
split_part(x, delimiter, part)
  • part: index of the field to return.
split_to_map
Splits a character string using the first delimiter, and then splits the string again using the other delimiter.
  • delimiter01: delimiter 1.
  • delimiter02: delimiter 2.
Examples
  • split
    Splits a target character string according to a specified string. limit specifies the maximum number of words to split into. If this parameter is not specified, all words are split by default.
    1. Example field
    2. Query and analysis statement
      SELECT split(Id,'-'), split(Id,'-',2)
    3. Query and analysis result
      Table 1 Query and analysis result of the split function
      EXPR$0
      EXPR$1
      ["dc1dab7e","b045","4e77","bda4","914d083d1bf7"]
      ["dc1dab7e","b045-4e77-bda4-914d083d1bf7"]
  • split_part
    Splits a character string and returns the indexed content. The index starts from 0. If it is negative or greater than the number of substrings, an empty string is returned.
    1. Example field
      SELECT split_part(Id,'-',1)
      Table 2 Query and analysis result of the split_part function
      EXPR$0
      b045
  • split_to_map
    Splits a character string using the first delimiter, and then splits the string again using the other delimiter. The result is displayed in format {"KEY1":"VALUE1","KEY2":"VALUE2"}. If a value cannot be split again, it is left blank.
    1. Example field
      Request: request_id:"e3ac4b70c7d244f080d434e300d8065a"; request_time: "1674965051000"
      SELECT split_to_map(Request,';',':')
      Table 3 Query and analysis result of the split_to_map function
      EXPR$0
      {"request_id ":"e3ac4b70c7d244f080d434e300d8065a ","request_time":"1674965051000"}
