Updated on 2025-07-11 GMT+08:00
Event Monitoring
Overview
Event monitoring provides event data reporting, query, and alarm reporting. You can create alarm rules for both system events and custom events. When there are specified events, you will receive alarm notifications.
Namespace
SYS.ESW
Monitoring Events
Table 1 Monitoring events supported by Enterprise Switch
Event Source
Namespace
Event Name
Event ID
Event Severity
Solution
Impact
SYS.ESW
IP Address Conflict
IPConflict
Major
A cloud server and an on-premises server that need to communicate use the same IP address.
Check the ARP and switch information to locate the servers that have the same IP address and change the IP address.
The communications between the on-premises and cloud servers may be abnormal.
