Help Center/
Data Lake Insight/
User Guide/
Creating an Elastic Resource Pool and Creating Queues Within It/
Managing Queues/
Viewing Basic Information About a Queue
Updated on 2025-08-15 GMT+08:00
This section walks you through how to view basic information about a queue on the management console, including the engine type and version.
- Log in to the DLI management console.
- In the navigation pane on the left, choose Resources > Queue Management.
- On the displayed page, locate the queue whose basic information you want to view.
- In the upper right corner of the list page, click
to customize the columns to display and set the rules for displaying the table content and the Operation column. - In the search box above the list, you can filter the required queue by name or tag.
- Click
to view queue details.
The parameters of the queue are:
- Engine: type of the engine that executes jobs on the queue.
- Default Version: default version of the execution engine or the version the system will use if no specific version is specified.
- Supported Versions: all versions supported by the execution engine. By viewing the supported versions of the queue, you can find out which versions of the execution engine can be used to process jobs on the queue.
Figure 1 Basic queue information
