Querying Logs for SQL Jobs
DLI job buckets are used to store temporary data generated during DLI job running, such as job logs and results.
This section describes how to configure a bucket for DLI jobs on the DLI console and obtain SQL job logs.
Notes
- To avoid disordered job results, do not use the OBS bucket configured for DLI jobs for any other purposes.
- DLI jobs must be set and modified by the main account as IAM users do not have required permissions.
- You cannot view the logs for DLI jobs before configuring a bucket.
- You can configure lifecycle rules to periodically delete objects from buckets or change storage classes of objects.
- Exercise caution when modifying the job bucket, as it may result in the inability to retrieve historical data.
Before the configuration, create an OBS bucket or parallel file system (PFS). In big data scenarios, you are advised to create a PFS. PFS is a high-performance file system provided by OBS, with access latency in milliseconds. PFS can achieve a bandwidth performance of up to TB/s and millions of IOPS, which makes it ideal for processing high-performance computing (HPC) workloads.
For details about PFS, see "Parallel File System Feature Guide" in the Object Storage Service User Guide.
Configuring a Bucket for DLI Jobs
- In the navigation pane of the DLI console, choose Global Configuration > Project.
- On the Project page, click
next to Job Bucket to configure bucket information.
Figure 1 Project
- Click
to view available buckets. - In the displayed OBS dialog box, click the name of a bucket or search for and click a bucket name and then click OK. In the Set Job Bucket dialog box, click OK.
Temporary data generated during DLI job running will be stored in the OBS bucket.Figure 2 Setting the job bucket
- Log in to the DLI console. In the navigation pane on the left, choose Job Management > SQL Jobs.
- Select the SQL job whose jobs you want to query, click More in the Operation column, and select View Log.
The system automatically switches to the log path of the DLI job bucket.
- On the Files tab, select the log file of the desired date and time and click Download in the Operation column to download the file to your local host.
Figure 3 Downloading SQL job logs
