Updated on 2026-09-08 GMT+08:00
Managing Queue Tags
Tag Management
A tag is a user-defined key-value pair used to identify cloud resources, helping you classify and search for them. A tag consists of a tag key and a tag value.
If you use tags in other cloud services, you are advised to create the same tag (key-value pairs) for cloud resources used by the same business to keep consistency.
DLI supports the following two types of tags:
  • Resource tags: non-global tags created on DLI
If your organization has configured tag policies for DLI, add tags to resources based on the policies. If a tag does not comply with the tag policies, resource creation may fail. Contact your organization administrator to learn more about tag policies.
DLI allows you to add, modify, or delete tags for queues.
  1. In the navigation pane on the left of the DLI management console, choose Resources > Queue Management.
  2. In the Operation column of the queue, choose More > Tags.
  3. The tag management page is displayed, showing the tag information about the current queue.
  4. On the page that appears, click Add/Edit Tag in the upper left corner. Enter a tag and a value, and click Add.
    Figure 1 Adding/Editing tags
    Table 1 Tag parameters
    Tag key
    You can specify the tag key in either of the following ways:
    • Click the text box and select a predefined tag key from the drop-down list.
      To add a predefined tag, you need to create one on TMS and then select it from the Tag key drop-down list. You can click View predefined tags to go to the Predefined Tags page of the TMS console. Then, click Create Tag in the upper corner of the page to create a predefined tag.
      For details, see Creating Predefined Tags in Tag Management Service User Guide.
    • Enter a tag key in the text box.
      A tag key can contain a maximum of 128 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed, but the value cannot start or end with a space or start with _sys_.
    Tag value
    You can specify the tag value in either of the following ways:
    • Click the text box and select a predefined tag value from the drop-down list.
    • Enter a tag value in the text box.
      A tag value can contain a maximum of 255 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed.
    • A maximum of 20 tags can be added.
    • Only one tag value can be added to a tag key.
    • The key name in each resource must be unique.
  5. Click OK.
  6. (Optional) To delete a tag, locate the row where the tag resides in the tag list and click Delete in the Operation column to delete the tag.
