SQL Job Management
SQL jobs allow you to execute SQL statements in the SQL job editing window, import data, and export data.
SQL job management provides the following functions:
- Searching for Jobs: Search for jobs that meet the search criteria.
- Viewing Job Details: Display job details.
- Terminating a Job: Stop a job in the Submitting or Running status.
- Exporting SQL Job Results: Stores the data results of analyzed SQL jobs in a specified location in the desired format.
SQL Jobs Page
On the Overview page of the DLI console, click SQL Jobs to go to the SQL job management page. Alternatively, you can click Job Management > SQL Jobs. The job list displays all SQL jobs. If there are a large number of jobs, they will be displayed on multiple pages. You can switch to the specified page as needed. DLI allows you to view jobs in all statuses. By default, jobs in the job list are displayed in descending order of the job creation time.
Parameter |
Description |
Queues |
Name of the queue to which a job belongs |
Engine |
SQL jobs support the Spark and Trino engines.
Username |
Name of the user who executed the job. |
Type |
Job type. The following types are supported:
Status |
Job status. Possible values are as follows:
Query |
SQL statements for operations such as exporting and creating tables You can click to copy the query statement. |
Duration |
Running duration of a job |
Created |
Time when a job is created. Jobs can be displayed in ascending or descending order of the job creation time. |
Operation |
The View Log button is not available for synchronization jobs and jobs running on the default queue. |
Searching for a Job
On the SQL Jobs page, you can search jobs with any of the following operations.
- Select a queue name.
- Select an engine.
- Set the date range.
- Enter a username, statement, tag, or job ID.
- Select the creation time in ascending or descending order.
- Select a job type.
- Select a job status.
- Select the job execution duration in ascending or descending order.
Viewing Job Details
On the SQL Jobs page, you can click in front of a job record to view details about the job.
Job details vary with job types. The job details vary depending on the job types, status, and configuration options. The following describes how to load data, create a table, and select a job. For details about other job types, see the information on the management console.
- Load data (job type: IMPORT) include the following information: queue, job ID, username, type, status, execution statement, running duration, creation time, end time, parameter settings, label, number of results, scanned data, number of scanned data, number of error records, storage path, data format, database, table, table header, separator, reference character, escape character, date format, timestamp format, total CPU used, and output bytes.
- Create table (job type: DDL) include the following information: queue, job ID, username, type, status, execution statement, running duration, creation time, end time, parameter settings, tags, number of results, scanned data, and database.
- Select (job type: QUERY) include the following information: queue, job ID, username, type, status, execution statement, running duration, creation time, end time, parameter setting, label, number of results (results of successful executions can be exported), and scanned data, username, result status (results of successful tasks can be viewed. Failure causes of failed tasks are displayed), database, total CPU used, and output bytes.
- Total CPU Used (Core x ms): total CPU used during job execution.
- Output Bytes: number of output bytes after the job is executed.
