- What's New
- Getting Started
- User Guide
Best Practices
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Troubleshooting a Custom Script Error
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
- API Reference
About Concepts
- What Is CSBS?
- What Are Full Backup and Incremental Backup?
- What Is Consistent Backup?
- What Are the Differences Between CSBS and VBS?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- What Are the Differences Between Backup and Snapshot?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
About Pricing
- How Is CSBS Billed?
- How Do Yearly/Monthly Resource Packages Function When I Have Bought More Than One?
- Are CSBS and VBS Resource Packages Interoperable Between CSBS and VBS?
- Why Am I Charged in Pay-per-use Mode Although I Have Purchased Resource Package?
- What Exactly Are the Function Package and the Storage Package?
- Will the CSBS Backups Displayed on the VBS Page Be Charged Repeatedly?
- How Do I Query CSBS Pay-Per-Use Billing Details?
- Why Is the Fee Deducted After a Backup Is Deleted?
- How Do I Disable CSBS?
- How Do I Stop CSBS from Charging?
About Backup
- Does CSBS Support Backing Up All EVS Disks on an ECS?
- Do I Need to Stop the ECS Before Backing It Up?
- Can an ECS with Application Systems Be Backed Up?
- What Are the Minimum Backup Frequency and Maximum Number of Retained Backups Supported by CSBS?
- How Can I Distinguish Automatic Backups From Manual Backups?
- How Can I Configure a Backup Policy?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CSBS Support Cross-Region Backup for ECSs?
- Which Types of Databases Can Be Backed Up Using Database Server Backup?
- How Do I Select Among Database Server Backup, Cloud Server Backup, and Disk Backup?
- How Do I Migrate ECS Data Across Regions Using CSBS?
- Which Time Zone Is the Automatic Backup Time Based On?
- What Can I Do If a Backup Cannot Be Deleted?
- About Restoration
- Others
About Concepts
- Troubleshooting
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Getting Started
- Management Operations
- About Concepts
About Backup
- About Restoration
- Others
- Troubleshooting Cases
- Change History
- API Reference (Paris and Amsterdam Regions)
Show all
Creating an Application-Consistent Backup
CSBS supports crash-consistent backup and application-consistent backup. Application-consistent backup ensures the consistency of applications between the file/disk data and the backup data. This backup mode suits scenarios such as backing up ECSs with MySQL or SAP HANA databases.
On CSBS Console, application-consistent backups can be created using any of the following methods:
- Manual backup: When creating a cloud server backup, you can manually perform application-consistent backup at a time.
- Automatic backup: Enable application-consistent backup in the backup policy to periodically create application-consistent backups.
- Executing a backup policy: Select a backup policy where application-consistent backup is enabled and manually perform the backup operation.
This section describes how to create an application-consistent backup using the first method. For details about how to use the second and third methods, see Creating a Backup Policy and Executing a Backup Policy at Once respectively.
The following constraints and restrictions apply to the three methods.
Constraints and Limitations
- Application-consistent backup for clusters, for example, MySQL clusters, is not supported. Application-consistent backup is supported only for a single server.
- You are advised to perform application-consistent backup in off-peak hours.
- Application-consistent backup for bare metal servers is supported.
- Log in to the CSBS management console.
- Under Storage > Cloud Server Backup Service.
- In the upper right corner of the page, click Create CSBS Backup.
- In the server list, select the servers you want to back up. After servers are selected, they are added to the list of selected servers.
- In the Configure Backup area, configure a backup scheme for the selected ECSs and then select Back Up Now. For details about the parameters, see Creating a CSBS Backup.
- Determine whether to select Enable next to Application-Consistent Backup. If selected, the system will perform application-consistent backups. If you select Continue to back up data after the application-consistent backup fails. at the same time, the system will perform crash-consistent backup if the application-consistent backup job fails. Otherwise, the whole backup operation fails.
Before using application-consistent backup, change the security group and install the Agent. For details, see Changing a Security Group.
- Click Next.
- Check the details, confirm the settings, and click Submit.
- Return to the CSBS page as prompted. If the execution fails, rectify the fault based on the error details on the creation result page.
On the Backup tab page, if the value of Backup Status is Available and the value of A next to the backup name is blue, the application-consistent backup job is successfully executed. If A next to the backup name is gray, the application-consistent backup job fails to be executed.
