Updated on 2025-07-29 GMT+08:00
Querying Password Change Records
After you configure password change, the host account password is changed periodically based on the configured period. You can view the final password change result and the new password for the account.
Obtaining the Account Password Change Records
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resource O&M > Automated O&M.
  3. Go to the Routine O&M page and click Account Management.
  4. Choose Accounts > By Resource or By Application.
    • By Resource applies to all purchased host instances.
    • By Application applies to purchased hosts that have been bound to an application. If you select By Application, you need to select the target application or component.
  5. Select a resource type.
    By default, Elastic Cloud Server (ECS) is selected.
  6. Select the host to be viewed and choose More > Password change record in the Operation column.
    View the password change records of the host.
    The password change record dialog box displays the password change time and status of the host account. You can filter the password change results by password change status and account name. If the password change status is succeeded, click Obtain Password in the Operation column to obtain the new password.
