Managing Patch Baselines
You can customize a patch baseline to scan the patches of an instance. The patches that do not comply with the baseline can be fixed.
You can create patch baselines for ECS, CCE, and BMS instances as required.
Cloud Operations Center has provided the public patch baselines of all OSs as the preset patch baseline when ECS and BMS instances are used initially. Patch baseline for CCE instances needs to be manually created.
Precautions
The common baseline cannot be modified or deleted.
Creating a Patch Baseline
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M.
- In the Routine O&M area, click Patch Management.
- On the displayed page, click the Patch Baseline tab.
- Click Create Patch Baseline and set the parameters.
Table 1 Basic information parameters Parameter
Example Value
Baseline Name
Customize the name of the patch baseline based on the naming rule.
Test baseline
(Optional) You can describe the remarks or usage instructions of the baseline.
Scenario Type
The value can be ECS, CCE, or BMS.
ECS
OS
The value can be Huawei Cloud EulerOS, CentOS, or EulerOS.
Default Baseline or Not
Select the option to set this patch as the default patch baseline.
Baseline Type
Select a baseline type.
Table 2 Installation rule baseline Parameter
Option
Product
- Huawei Cloud EulerOS
- All
- Huawei Cloud EulerOS 1.1
- Huawei Cloud EulerOS 2.0
- CentOS
- All
- CentOS 7.2
- CentOS 7.3
- CentOS 7.4
- CentOS 7.5
- CentOS 7.6
- CentOS 7.7
- CentOS 7.8
- CentOS 7.9
- CentOS 8.0
- CentOS 8.1
- CentOS 8.2
- EulerOS
- All
- EulerOS 2.2
- EulerOS 2.5
- EulerOS 2.8
- EulerOS 2.9
- EulerOS 2.10
Product for which you want to scan patches. Only the patches of the selected product are scanned and fixed.
Category
- All
- Security
- Bugfix
- Enhancement
- Recommended
- New package
Category of patches. Only the patches of the selected category are scanned and fixed.
Severity
- All
- Critical
- Important
- Moderate
- Low
- None
Severity level of patches. Only the patches of the selected severity are scanned and fixed.
Automatic Approval
- Approve the patch after a specified number of days.
- Approve patches released before the specified date.
Automatically approve patches that meet specified conditions.
Specified Days
0-365
This parameter is mandatory when Approve the patch after a specified number of days. is selected.
Specified Days
This parameter is mandatory when Approve patches released before the specified date. is selected.
Compliance Reporting
- Unspecified
- Critical
- High
- Medium
- Low
- Suggestion
Level at which patches that meet the patch baseline are displayed in the compliance report
Install Non-Security Patches
If you do not select this option, the patches with vulnerabilities will not be updated during patch repairing.
Abnormal Patches
Approved patches and rejected patches can be in the following formats:
- Complete software package name: example-1.0.0-1.r1.hce2.x86_64
- Software package names that contain a single wildcard: example-1.0.0*.x86_64
Table 3 Custom baseline Parameter
Option
Product
- All
- CentOS
- All
- CentOS 7.2
- CentOS 7.3
- CentOS 7.4
- CentOS 7.5
- CentOS 7.6
- CentOS 7.7
- CentOS 7.8
- CentOS 7.9
- CentOS 8.0
- CentOS 8.1
- CentOS 8.2
- EulerOS
- All
- EulerOS 2.2
- EulerOS 2.5
- EulerOS 2.8
- EulerOS 2.9
- EulerOS 2.10
Unspecified
Critical
High
Medium
Low
Suggestion
Baseline Patches
None
You can customize the version and release number of a baseline path. Only the patches that match the customized baseline patch can be scanned and installed.
- A maximum of 1,000 baseline patches can be uploaded for a baseline.
- The patch name can contain a maximum of 200 characters, including letters, digits, underscores (_), hyphens (-), dots (.), asterisks (*), and plus signs (+).
- The data in the second column consists of the version number (including letters, digits, underscores, dots, and colons) and the release number (including letters, digits, underscores, and dots) that are separated by a hyphen (-). Both two types of numbers can contain a maximum of 50 characters.
- Click OK.
The patch baseline is created.
Setting a Default Baseline
- Log in to COC.
- Locate the target baseline and click Set Default Baseline in the Operation column.
The default baseline is set.
Modifying a Patch Baseline
- Log in to COC.
- Locate the target baseline and click Modify in the Operation column.
Table 4 Basic information parameters Parameter
Example Value
Baseline Name
Test baseline
Scenario Type
This parameter cannot be changed.
ECS
OS
Baseline Type
- Click OK.
The patch baseline is modified.
Deleting a Patch Baseline
- Log in to COC.
- Locate the target baseline and click Delete in the Operation column.
The patch baseline is deleted.
