When a LoadBalancer ingress is created in a CCE cluster, CCE automatically provisions a listener for the load balancer associated with the ingress on ELB and adds forwarding policies. By default, the ingress routes incoming client requests based on the domain name and path and directs the requests through the listener to the appropriate backend server, either a node or a pod, for processing. During LoadBalancer ingress creation, CCE allows you to define custom forwarding rules and actions for flexible, fine-grained traffic distribution.
Figure 1 How an advanced forwarding policy operates
An advanced forwarding policy operates as follows:
- The client initiates a request to the LoadBalancer ingress.
- The load balancer evaluates the request against the forwarding rules defined in the advanced forwarding policy.
- The load balancer forwards the request to the appropriate backend server based on the action specified in the forwarding rule.
- The backend server returns a response to the client.
For details about the forwarding rules and actions supported by advanced forwarding policies, see Forwarding Rules and Forwarding Actions.
- A CCE standard or Turbo cluster is available, and the cluster version meets the requirements.
- The cluster can be accessed using kubectl. For details, see Accessing a Cluster Using kubectl.
Notes and Constraints
CCE allows you to configure header writing/removal, rewriting, and limiting on requests, based on ELB's advanced forwarding for LoadBalancer ingresses. These functions are currently being rolled out, and availability depends on the actual regions that have been officially opened. To use some advanced forwarding actions that are not available on the console yet, submit a service ticket to enable required functions.
Forwarding Rules
LoadBalancer ingresses support advanced traffic routing by allowing you to configure forwarding rules using the kubernetes.io/elb.conditions.<svc-name> annotation. Incoming requests are evaluated against these rules. If the conditions are met, the requests are forwarded accordingly.
If you set up different rules for the same Service using the same annotation, they must all be matched for a request to go through. But if you set multiple values in the same rule, then the request only needs to match one of them. For example, if both Method and QueryString are configured, the traffic can be distributed only when both rules are met. However, if the Method value includes both GET and POST, the traffic can be distributed only when both rules are met and the request method is either GET or POST.
You can configure up to 10 advanced forwarding conditions (including domain names and paths) per ingress. Each individual value within a rule counts as one forwarding condition.
For example, if you define a domain name and a path for an ingress, there are two forwarding conditions, leaving eight remaining. If you then specify two HTTP methods, for example, GET and POST, two more forwarding conditions are used.
Table 1 ELB advanced forwarding rules
Forwarding Rule |
Description |
Reference |
Cluster Version |
HTTP request method |
Route HTTP requests based on the request type (such as GET and POST). If a request matches the specified rule, the defined forwarding action is used.
An annotation example is as follows:
kubernetes.io/elb.conditions.<svc-name>: |
"type": "Method",
"methodConfig": {
"values": [
"GET",
"POST"
For details about the configuration example and parameters of advanced forwarding rules, see Scenario 1: Configuring Advanced Forwarding Rules for a LoadBalancer Ingress. |
- v1.23: v1.23.18-r10 or later
- v1.25: v1.25.16-r0 or later
- v1.27: v1.27.16-r0 or later
- v1.28: v1.28.13-r0 or later
- v1.29: v1.29.8-r0 or later
- v1.30: v1.30.4-r0 or later
- Other clusters of later versions
HTTP request header |
Route requests based on the specific information (such as User-Agent and Content-Type) in HTTP request headers. If a request matches the specified rule, the defined forwarding action is used.
"type": "Header",
"headerConfig": {
"key": "gray-hello",
"values": [
"value1",
"value2"
Cookie |
Route requests based on the specified keys and values in cookies. If a request matches the specified rule, the defined forwarding action is used.
"type": "Header",
"headerConfig": {
"values": [
"value1",
"value2"
Query string |
Route requests based on the specific parameters and values of the query strings in the URLs. If a request matches the specified rule, the defined forwarding action is used.
"type": "QueryString",
"queryStringConfig": {
"key": "querykey",
"values": [
"queryvalue"
CIDR block |
Route requests based on the source IP addresses from where the requests originate. If a request matches the specified rule, the defined forwarding action is used.
"type": "SourceIp",
"sourceIpConfig": {
"values": [
"192.168.0.0/16",
"172.16.0.0/16"
Forwarding Actions
LoadBalancer ingresses allow you to define multiple forwarding actions through annotations. This gives you flexible control over how requests are handled. The supported forwarding actions include:
- (Default) Forward to a backend server group: Additional actions like rewrite, CORS, write/remove header, and limit request are supported. Load balancers handle requests based on these additional actions before forwarding them to backend server groups. Among all the additional actions, limit request has the highest priority.
- Redirect to another listener: HTTP requests can be redirected to an HTTPS listener.
- Return a specific response body: Additional actions such as limit request are supported.
- Forward to a custom backend server group: This action cannot be used together with grayscale release, return a specific response body, or redirect to another URL.
Table 2 ELB advanced forwarding actions
Forwarding Action |
Additional Action |
Description |
Reference |
Cluster Version |
(Default) Forward to a backend server group |
Rewrite |
Rewrite the request paths.
kubernetes.io/elb.rewrite-target: /rewritepath |
For details about the configuration example and parameters, see Configuring URL Rewriting for a LoadBalancer Ingress. |
- v1.23: v1.23.14-r0 or later
- v1.25: v1.25.9-r0 or later
- v1.27: v1.27.6-r0 or later
- v1.28: v1.28.4-r0 or later
CORS |
Support cross-origin access of resources.
kubernetes.io/elb.cors-allow-origin: 'http://example.com' # The origin that can be accessed
kubernetes.io/elb.cors-allow-headers: 'fake-header-1' # The allowed request header
kubernetes.io/elb.cors-expose-headers: 'fake-header-2' # The response header to be exposed
kubernetes.io/elb.cors-allow-methods: 'GET,POST' # The allowed HTTP request methods
kubernetes.io/elb.cors-allow-credentials: 'true' # Credentials can be sent.
kubernetes.io/elb.cors-max-age: '3600' # The cache duration of a pre-check request |
For details about the configuration example and parameters, see Configuring Cross-Origin Access for LoadBalancer Ingresses. |
Write/Remove header |
Write or delete the configured header in a request before accessing the backend server.
kubernetes.io/elb.actions.<svc-name>: |
"type": "InsertHeader",
"InsertHeaderConfig": {
"key": "insertkey",
"value_type": "USER_DEFINED",
"value": "insertvalue"
"type": "RemoveHeader",
"RemoveHeaderConfig": {
"key": "removekey"
For details about the configuration example and parameters, see Example 1: Configuring Write/Remove Header for a LoadBalancer Ingress. |
Limit request |
Support rate limiting on requests.
"type": "TrafficLimit",
"trafficLimitConfig": {
"QPS": 4,
"perSourceIpQps": 2,
"burst": 2
For details about the configuration example and parameters, see Example 3: Configuring Limit Request for a LoadBalancer Ingress. |
- v1.27: v1.27.16-r10 or later
- v1.28: v1.28.15-r0 or later
- v1.29: v1.29.10-r0 or later
- v1.30: v1.30.6-r0 or later
Redirect to another listener (HTTP requests redirected to an HTTPS listener) |
None |
Forward HTTP access requests to an HTTPS listener.
kubernetes.io/elb.ssl-redirect: 'true'
kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]' # Forward HTTP requests to an HTTPS port. |
For details about the configuration example and parameters, see Redirecting HTTP to HTTPS for a LoadBalancer Ingress. |
Redirect to another URL |
None |
Redirect specific requests to a specified URL and return a 3xx return code.
kubernetes.io/elb.redirect-url: https://example.com/testa # Information about the redirection to a URL
kubernetes.io/elb.redirect-url-code: '301' # Code returned after the ingress is redirected to a URL |
For details about the configuration example and parameters, see Configuring URL Redirection for a LoadBalancer Ingress. |
Return a specific response body |
None |
Directly return a specific response body and do not continue to forward the response to the backend server.
"type": "FixedResponse",
"fixedResponseConfig": {
"contentType": "text/plain",
"statusCode": "503",
"messageBody": "503 error text"
For details about the configuration example and parameters, see Example 2: Configuring Return a Specific Response Body for a LoadBalancer Ingress. |
- v1.25: v1.25.16-r10 or later
Limit request |
"QPS": 4,
"burst": 2
Forward to a custom backend server group |
Forward LoadBalancer ingress requests to both pods in the CCE cluster (default backend server group) and an ECS group (custom backend server group) located outside the cluster.
"type": "ForwardPool",
"forwardConfig": [{
"serviceName": "test",
"servicePort": 80,
"weight": 90,
"type": "service"
"poolID": "53d8516e-xxxx-xxxx-xxxx-b15ffd6b3cca",
"weight": 70,
"type": "pool"
For details about the configuration example and parameters, see Example 4: Configuring the Forward to a Custom Backend Server Group Action for a LoadBalancer Ingress. |
- v1.25: v1.25.16-r20 or later
- v1.27: v1.27.16-r20 or later
- v1.28: v1.28.15-r10 or later
- v1.29: v1.29.10-r10 or later
- v1.30: v1.30.6-r10 or later
- v1.31: v1.31.4-r0 or later
LoadBalancer ingresses can route traffic based on custom HTTP request methods, request headers, query strings, and source CIDR blocks. In this example, traffic is routed to the svc-hello1 Service only when the request path is /hello1 and the following advanced forwarding rules are met:
- The request method is GET or POST.
- The key in the request header is gray-hello, and the value is value1 or value2.
- The key of the cookie is cookiekey1 and the value is cookievalue1, or the key of the cookie is cookiekey2 and the value is cookievalue2.
- The key of the query string is querykey, and the value is queryvalue.
- The source CIDR block is 192.168.0.0/16 or 172.16.0.0/16.
The operations and parameter settings are as follows:
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress created using an existing load balancer is as follows:
kind: Ingress
annotations:
kubernetes.io/elb.class: performance
kubernetes.io/elb.id: ab53c3b2-xxxx-xxxx-xxxx-5ac3eb2887be
kubernetes.io/elb.port: '80'
# The following annotation indicates that the advanced forwarding rules are configured for the svc-hello1 Service. The Service name must be the same as that in the backend field.
kubernetes.io/elb.conditions.svc-hello1: |
"type": "Method",
"methodConfig": {
"values": [
"GET",
"POST"
"type": "Header",
"headerConfig": {
"values": [
"value1",
"value2"
"type": "Cookie",
"cookieConfig": {
"values": [
"key": "cookiekey1",
"value": "cookievalue1"
"key": "cookiekey2",
"value": "cookievalue2"
"key": "querykey",
"values": [
"queryvalue"
"type": "SourceIp",
"sourceIpConfig": {
"values": [
"192.168.0.0/16",
"172.16.0.0/16"
ingressClassName: cce
rules:
- http:
paths:
- path: /hello1
backend:
service:
port:
number: 80
Table 3 Annotation for advanced forwarding rules
Parameter |
Type |
Description |
kubernetes.io/elb.conditions.${svc_name} |
String |
Configure advanced forwarding rules. ${svc_name} indicates the Service name, which can contain a maximum of 48 characters.
If the annotation value is set to [], the advanced forwarding rules will be deleted.
The annotation value is a JSON array. For details, see Table 4.
CAUTION:
If you set up different rules for the same condition array, they must all be matched for a request to go through. But if you set multiple values in the same rule, then the request only needs to match one of them. For example, if both Method and QueryString are configured, the traffic can be distributed only when both rules are met. However, if the Method value includes both GET and POST, the traffic can be distributed only when both rules are met and the request method is either GET or POST.
Table 4 Array structure
Parameter |
Description |
Example |
type |
Matching type. Options:
- Method: HTTP requests are forwarded based on the matched method. This parameter must be used with methodConfig. Method can be configured only once.
- Header: HTTP requests are forwarded based on the matched header. This parameter must be used with headerConfig.
- Cookie: HTTP requests are forwarded based on the matched cookie. This parameter must be used with cookieConfig.
- QueryString: HTTP requests are forwarded based on the matched character string. This parameter must be used with queryStringConfig.
- SourceIp: HTTP requests are forwarded based on the matched CIDR block. This parameter must be used with sourceIpConfig. SourceIp can be configured only once.
None |
methodConfig |
An HTTP request method that is used to forward requests. This parameter is used only when type is set to Method.
Multiple methods can be concurrently configured, including GET, POST, PUT, DELETE, PATCH, HEAD, and OPTIONS. |
You do not need to configure keys for methodConfig. You only need to configure values (an array) for methodConfig.
"type": "Method",
"methodConfig": {
"values": [
"GET",
"POST"
headerConfig |
An HTTP request header that is used to forward requests. This parameter is used only when type is set to Header.
You can only configure one key for each headerConfig rule. If you need multiple keys, configure multiple headerConfig rules.
"type": "Header",
"headerConfig": {
"values": [
"value1",
"value2"
cookieConfig |
A cookie that is used to forward requests. This parameter is used only when type is set to Cookie. A cookie consists of a key and a value, which must be configured separately.
- A key can contain 1 to 100 characters and cannot start or end with a space.
- A value can contain 1 to 100 characters. Configure a value for each key.
You can enter multiple key-value pairs that can contain letters, digits, and special characters (!%'"()*+,./:=?@^-_`~). |
When configuring cookieConfig, you can configure multiple key-value pairs in values, and these pairs will have an OR relationship with each other.
"type": "Cookie",
"cookieConfig": {
"values": [
queryStringConfig |
A character string that is used to forward requests. If the character string in a request matches the one in the configured forwarding rule, the request will be forwarded. This parameter is used only when type is set to QueryString.
A query string consists of a key and one or more values. Configure the key and values separately.
- A key can only contain letters, digits, and special characters !$'()*+,./:;=?@^-_'.
- Multiple values can be configured for a key. A value can only contain letters, digits, and special characters !$'()*+,./:;=?@^-_'. Asterisks (*) and question marks (?) can be used as wildcard characters.
You can only configure one key for each queryStringConfig rule. If you need multiple keys, configure multiple QueryStringConfig rules.
"key": "querykey",
"values": [
"queryvalue"
sourceIpConfig |
A CIDR block that is used to forward requests. This parameter is used only when type is set to SourceIp.
Example CIDR block: 192.168.1.0/24 or 2020:50::44/127 |
You do not need to configure keys for sourceIpConfig. You only need to configure values (an array) for sourceIpConfig.
"type": "SourceIp",
"sourceIpConfig": {
"values": [
"192.168.0.0/16",
"172.16.0.0/16"
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE
ingress-test cce * 121.**.**.** 80 10s
Scenario 2: Configuring Advanced Forwarding Actions for a LoadBalancer Ingress
The examples describe how to configure actions like write/remove header, return a specific response body, limit request, and forward to a custom backend server group for a LoadBalancer ingress.
You can modify or delete the headers specified in requests. In this example, when a user accesses the ingress, the load balancer will:
- Write the user-defined header (aa:aa), system-defined header (bb:ELB-ID), and user-referenced header (cc:cc) to the requests.
- Delete the headers with the dd or ee keys.
kind: Ingress
annotations:
kubernetes.io/elb.id: *****
kubernetes.io/elb.port: "80"
# The following annotation applies to the test-service Service and is used to configure the write/remove header action for it.
kubernetes.io/elb.actions.test-service: |
"key": "aa",
"value": "aa"
"key": "bb",
"value_type": "SYSTEM_DEFINED",
"value": "ELB-ID"
"key": "cc",
"value_type": "REFERENCE_HEADER",
"value": "cc"
"key": "dd"
"key": "ee"
namespace: default
rules:
- http:
paths:
- backend:
service:
port:
number: 80
path: /
property:
Table 5 Annotations for advanced forwarding actions
Parameter |
Type |
Description |
kubernetes.io/elb.actions.${svc_name} |
String |
Configure an advanced forwarding action for an ingress. ${svc_name} indicates the Service name, which can contain a maximum of 51 characters.
If the annotation value is set to [], all advanced forwarding actions will be deleted.
The value of the annotation for configuring header writing or deletion is a JSON string array. For details, see Table 6. For example:
[{"type":"InsertHeader","InsertHeaderConfig":{"key":"aa","value_type":"USER_DEFINED","value":"aa"}}] |
Table 6 Parameters for rewriting a header
Parameter |
Description |
Example |
type |
Type of header rewriting. Options:
- InsertHeader: The header will be written. This field must be used with InsertHeaderConfig.
- RemoveHeader: The header will be deleted. This field must be used with RemoveHeaderConfig.
For advanced forwarding actions, you can add a maximum of five header writing or deletion configurations to an annotation.
None |
InsertHeaderConfig |
The header that will be written. This parameter is used only when type is set to InsertHeader.
- key: key of the rewritten header. A key consists of 1 to 40 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. A key cannot contain any of the following characters (case-insensitive):
connection, upgrade, content-length, transfer-encoding, keep-alive, te, host, cookie, remoteip, authority, x-forwarded-host, x-forwarded-for, x-forwarded-for-port, x-forwarded-tls-certificate-id, x-forwarded-tls-protocol, x-forwarded-tls-cipher, x-forwarded-elb-ip, x-forwarded-port, x-forwarded-elb-id, x-forwarded-elb-vip, x-real-ip, x-forwarded-proto, x-nuwa-trace-ne-in, or x-nuwa-trace-ne-out
- value_type: type of the header to be written. If the header is deleted, this parameter becomes invalid. Options:
- USER_DEFINED: custom header
- REFERENCE_HEADER: header referenced by a user
- SYSTEM_DEFINED: header defined by the system
- value: value of the header to be written. If the header is deleted, this parameter becomes invalid. The value can contain 1 to 128 characters. ASCII codes 32 through 127 printable characters, asterisk (*), and question mark (?) are also supported. The value cannot start or end with a space.
If value_type is set to SYSTEM_DEFINED, the value can only be CLIENT-PORT, CLIENT-IP, ELB-PROTOCOL, ELB-ID, ELB-PORT, ELB-EIP, or ELB-VIP.
"key": "aa",
"value": "aa"
RemoveHeaderConfig |
The header that will be deleted. This parameter is used only when type is set to RemoveHeader.
- key: key of the deleted header. A key consists of 1 to 40 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. A key cannot contain any of the following characters (case-insensitive):
"key": "ee"
kubectl get ingress
You can configure a specific response status code and content for a LoadBalancer ingress. In this example, when a user accesses the ingress, the status code 503 and "503 error text" are returned.
kind: Ingress
annotations:
# The following annotation applies to the test-service Service and is used to configure the return a specific request body action for it.
namespace: default
rules:
- http:
paths:
- backend:
service:
port:
number: 80
path: /
property:
Table 7 Annotations for advanced forwarding actions
Parameter |
Type |
Description |
String |
The annotation value of a fixed response is a JSON string array. For details, see Table 8. |
Table 8 Parameters for a fixed response
Parameter |
Description |
Example |
type |
The value is fixed at FixedResponse, indicating that a fixed response will be returned.
For advanced forwarding actions, you can add a maximum of one fixed response configuration to an annotation.
None |
fixedResponseConfig |
- contentType: format of the returned content. The options are text/plain, text/css, text/html, application/javascript, and application/json.
- statusCode: By default, 2xx, 4xx, and 5xx status codes are supported.
- (Mandatory) messageBody: Enter 0 to 1024 characters.
NOTICE:
This parameter cannot be left empty when rate limiting is configured.
kubectl get ingress
You can configure limit request for a LoadBalancer ingress. In this example, when a user accesses the ingress, limit request is applied. The Queries Per Second (QPS) is set to 4, with a per-client source IP address QPS limit of 2. Additionally, up to 2 extra requests in a burst above the QPS limit is allowed during brief traffic spikes.
kind: Ingress
annotations:
# The following annotation applies to the test-service Service and is used to configure the limit request action for it.
"QPS": 4,
"burst": 2
namespace: default
rules:
- http:
paths:
- backend:
service:
port:
number: 80
path: /
property:
Table 9 Annotations for advanced forwarding actions
Parameter |
Type |
Description |
String |
The value of an annotation for configuring traffic limit is a JSON array. For details, see Table 10. |
Table 10 Parameters for configuring traffic limit
Parameter |
Description |
Example |
type |
The value is fixed at TrafficLimit, indicating that traffic limit is enabled for a load balancer.
For advanced forwarding actions, you can add a maximum of one traffic limit configuration to an annotation.
None |
trafficLimitConfig |
- QPS: the total traffic limit, which specifies the maximum QPS value. The value ranges from 0 to 100000. Value 0 means no limit. If the number of requests reaches the specified value, new requests will be discarded and 503 Service Unavailable will be returned to the client.
- (Optional) perSourceIpQps: traffic limit per client source IP address. The value ranges from 0 to 100000. Value 0 means no limit.
If both QPS and perSourceIpQps are configured, the latter value must be smaller than the former. If the number of requests reaches the specified value, new requests will be discarded and 503 Service Unavailable will be returned to the client.
- (Optional) burst: the size of a burst buffer. The value ranges from 0 to 100000. The burst rate enables temporary surges above the average rate to manage sudden spikes in requests. For instance, if the limit is set to 5 but the burst rate is 10, five more requests can be processed within 1 second. However, if the number of requests exceeds 10, only five requests are allowed within 1 second.
CAUTION:
After trafficLimitConfig is configured, deleting a single field in it on CCE does not remove the corresponding configuration from ELB. To disable rate limiting, set the parameter value to 0. To completely remove the rate limiting, delete the entire trafficLimitConfig field.
"QPS": "4",
"perSourceIpQps": "2",
"burst": "2"
kubectl get ingress
- Configuring a custom backend server group for a LoadBalancer ingress is subject to the capabilities of your ELB service. Before using this feature, submit a service ticket to enable the required ELB capabilities.
- The forward to a custom backend server group action cannot be used together with grayscale release, return a specific response body, or redirect to another URL.
- If you configure the forward to a custom backend server group action for a LoadBalancer ingress, the number field for the backend Services of the ingress will be invalid and the Service port name must be set to use-annotation. For details, see the example provided in this section.
- When configuring the forward to a custom backend server group action for a LoadBalancer ingress, ensure that each Service name and backend server group ID are unique.
- If you configure the kubernetes.io/elb.slowstart or kubernetes.io/elb.pool-protocol annotation when configuring the forward to a custom backend server group action for a LoadBalancer ingress, the annotation applies only to the default backend server groups automatically created by CCE. It does not apply to any custom backend server groups configured on ELB.
You can forward requests from an ingress to multiple custom backend server groups by weight. In this example, when a user accesses example.com, traffic is distributed between two backend server groups. Some is distributed to the backend server group associated with the test Service, assigned a weight of 90. The remaining traffic is directed to the load balancer's backend server group, which has a weight of 70.
kind: Ingress
annotations:
# The following annotation is used to configure a backend server group associated with a Service and a load balancer's backend server group for the ingress. forward-demo is the Service name in the backend field.
kubernetes.io/elb.actions.forward-demo: |
"forwardConfig": [{
"servicePort": 80,
"weight": 90,
"type": "service"
"poolID": "*****",
"weight": 70,
"type": "pool"
namespace: default
rules:
- host: example.com
http:
paths:
- backend:
service:
name: forward-demo # When configuring a custom backend server group, ensure that it has the same name as the Service specified in the annotation. In this example, the Service name is forward-demo.
port:
name: use-annotation # When you configure a custom backend server group, the original port.number field becomes invalid. You must instead specify the port.name parameter and set it to use-annotation.
path: /
property:
Table 11 Annotations for advanced forwarding actions
Parameter |
Type |
Description |
String |
The value of an annotation for configuring a custom backend server group is a JSON string array. For details, see Table 12. |
Table 12 Parameters for configuring a custom backend server group
Parameter |
Description |
Example |
type |
The value is fixed at ForwardPool, indicating that a custom backend server group is configured for a load balancer.
A maximum of one custom backend server group can be added to an advanced forwarding action annotation.
None |
forwardConfig |
A maximum of five custom backend server groups can be added to this parameter.
- type: type of a custom backend server group, which can be service or pool.
- service: CCE automatically creates a backend server group for each Service and manages its lifecycle.
- pool: You need to create and maintain the backend server group on the ELB console.
- poolID: mandatory when type is set to pool.
This parameter specifies the ID of the backend server group under the target ingress's load balancer. The ID must be unique for each group.
You can go to the backend server group list, search for the backend server group of a load balancer using the name or ID of the load balancer associated with the ingress, and obtain the group ID.
- serviceName: mandatory when type is set to service.
Before configuring a Service name, ensure that it is unique and the Service exists in the cluster.
- servicePort: mandatory when type is set to service.
This parameter specifies a Service port.
- weight: weight for distributing traffic to each backend server group, ranging from 0 to 100.
"forwardConfig": [{
"servicePort": 80,
"weight": 90,
"type": "service"
"weight": 70,
"type": "pool"
kubectl get ingress
ingress-test cce example.com 121.**.**.** 80 10s
Combined Application Scenarios
Advanced forwarding rules and actions can be combined to meet various requirements. Some examples are shown in the table below.
Rules to Be Applied When an Ingress Is Accessed |
Actions to Be Performed |
Target Service (Backend Service) |
- Domain name: example.com
- Request path: /path1
- Other advanced forwarding rules:
- Request method: GET or POST
- Request header: gray-hello:value1 or gray-hello:value2
- Request cookie: cookiekey1:cookievalue1 or cookiekey2:cookievalue2
- Query string: querykey:queryvalue
- CIDR block: 192.168.0.0/16 or 172.16.0.0/16
The following actions will be performed during forwarding:
- Write the user-defined request header aa:aa.
- Delete the request header with the key dd.
test |
- Request path: /path2
- Return a specific response with status code 503 and the content 503 error text.
- Set the total QPS limit to 67 and limit the QPS per client source IP address to 3.
test2 |
- Path: /path3
- Forward to the backend server groups associated with the test (weight: 90) and test2 (weight: 10) and Services.
test and test2 |
The YAML file example is as follows:
kind: Ingress
namespace: default
annotations:
kubernetes.io/elb.listener-master-ingress: default/ingress-demo
# The following annotation applies to the test Service and is used to add multiple load balancer forwarding matching conditions to it.
kubernetes.io/elb.conditions.test: |
"type": "Method",
"methodConfig": {
"values": [
"GET",
"POST"
"type": "Header",
"headerConfig": {
"values": [
"value1",
"value2"
"type": "Cookie",
"cookieConfig": {
"values": [
"key": "querykey",
"values": [
"queryvalue"
"type": "SourceIp",
"sourceIpConfig": {
"values": [
"192.168.0.0/16",
"172.16.0.0/16"
# The following annotation applies to the test Service and is used to configure the write/remove header action for it.
kubernetes.io/elb.actions.test: |
"key": "aa",
"value": "aa"
"key": "dd"
# The following annotation applies to the test2 Service and is used to configure the return a specific response body and limit request actions for it.
kubernetes.io/elb.actions.test2: |
"TrafficLimItConfig": {
"perSourceIpQps": 3,
"qps": 67
# The following annotation applies to the test3 Service and is used to configure the write header, limit request, and forward to custom backend server groups (associated with test and test2) actions for it.
kubernetes.io/elb.actions.test3: |
"key": "aa",
"value": "aa"
"forwardConfig": [{
"servicePort": 80,
"weight": 90,
"type": "service"
"serviceName": "test2",
"servicePort": 80,
"weight": 10,
"type": "service"
"qps": 67
rules:
- host: example.com
http:
paths:
- path: /path1
backend:
service:
port:
number: 80
property:
- path: /path2
backend:
service:
port:
number: 80
property:
- path: /path3
backend:
service:
port:
name: use-annotation # If the forward to custom backend server group ("type": "ForwardPool") action is specified, port.name must be set to use-annotation.
property:
