Binding a Security Group to a Pod Using an Annotation
In cloud native network 2.0, pods use VPC network interfaces or supplementary network interfaces for networking, which allow you to configure security groups. You can bind a security group to a pod by adding an annotation to the pod.
You can configure security groups in the following applications.
| Application | Annotation | Reference |
| Configure a pod's network interface security group via an annotation. | yangtse.io/security-group-ids | |
| Add an additional security group to a pod's network interface via an annotation, while retaining the existing security group. | yangtse.io/additional-security-group-ids |
Security groups can be associated with workloads through multiple methods: annotations, security group policies, node pool settings, or pod network settings. When multiple methods are used, only the highest-priority method applies. For details about priorities, see Comparison of Workload Security Group Configuration Methods.
- v1.23: v1.23.16-r0 or later
- v1.25: v1.25.11-r0 or later
- v1.27: v1.27.8-r0 or later
- v1.28: v1.28.6-r0 or later
- v1.29: v1.29.2-r0 or later
- Versions later than v1.29
Using kubectl
- Create a workload with a security group configured. The security group bound to the pod is subject to the one configured using an annotation.
If the pod has been bound to a security group, the configuration will be overwritten.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 3 selector: matchLabels: app: nginx template: metadata: labels: app: nginx annotations: yangtse.io/security-group-ids: ***** # Security group ID. Use commas (,) to separate multiple security groups. spec: containers: - name: container-0 image: nginx:alpine resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret - Add an additional security group for the workload.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 3 selector: matchLabels: app: nginx template: metadata: labels: app: nginx annotations: yangtse.io/additional-security-group-ids: ***** # Security group ID. Use commas (,) to separate multiple security groups. spec: containers: - name: container-0 image: nginx:alpine resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret
| Annotation | Description | Value Range |
| yangtse.io/security-group-ids | Configure a security group for a pod. The security group of the pod is subject to the one configured using this annotation. If the pod already has a security group, the original security group will be overwritten. | Security group IDs. Use commas (,) to separate multiple security groups. For better network performance, select no more than five security groups. If this parameter is left blank, no annotation will be used to configure a security group for the pod. |
| yangtse.io/additional-security-group-ids | Add more security groups to a pod. | Security group IDs. Use commas (,) to separate multiple security groups. For better network performance, keep no more than five security groups (existing and new). |
