Help Center/ Cloud Container Engine/ User Guide/ O&M/ O&M Best Practices/ Configuring Monitoring and Alarm Rules Using PrometheusRule
Updated on 2025-04-27 GMT+08:00
Prometheus provides PrometheusRule that defines monitoring and alarm rules. This allows you to better use Prometheus to query metrics based on monitoring rules and configure PromQL-based alarm rules.
Currently, PrometheusRule is only available when the Cloud Native Cluster Monitoring add-on works with local data storage enabled.
How Do I Configure Monitoring Rules Using PrometheusRule
  1. Create monitoring rules to query metrics using PrometheusRule.
    apiVersion: monitoring.coreos.com/v1
    kind: PrometheusRule
      namespace: monitoring
      labels:
        role: operator-prometheus   # (Mandatory) The value must be the same as that of the ruleSelector field configured in the Prometheus CR.
      groups:
      - name:  demo
        interval: 15s
        rules:
        - record: cpu_request
          expr:   kube_pod_container_resource_requests{resource="cpu",unit="core"}
        - record: cpu_limit
          expr:   kube_pod_container_resource_limits{resource="cpu",unit="core"}
        - record: memory_request
          expr:   kube_pod_container_resource_requests{resource="memory",unit="byte"}
        - record: memory_limit
          expr:   kube_pod_container_resource_limits{resource="memory",unit="byte"}
  2. Access the Prometheus web page and choose Status > Rules. On the displayed page, query the configured monitoring rules.
How Do I Configure Alarm Rules Using PrometheusRule?
You can configure a Prometheus custom resource (CR) that includes a PrometheusRule object to create alarm rules. The following uses the cluster CPU usage as an example to describe how to create an alarm rule template. For details, see https://prometheus.io/docs/prometheus/latest/configuration/alerting_rules/.
  1. Create an alarm rule template.
    kubectl apply -f PrometheusRule.yaml
    Example configuration of PrometheusRule.yaml:
      labels:
      groups:
      - name: alert-cluster-demo
        rules:
        - alert: The cluster CPU usage exceeds 50%.
          expr: 100 - (avg  (irate(node_cpu_seconds_total{mode="idle"}[2m])) * 100) >=50
          for: 2m
          labels:
            severity: critical
            cce_alert_kind: resources
            alertname: Cluster CPU usage exceeds 50%
            kind: resources
            resource_kind: Cluster
            resourceType: Cluster
            source: prometheus
          annotations:
            info: "The actual CPU usage of the cluster exceeds 50%. The current CPU usage of the cluster is {{ printf \"%.2f\" $value }}%".
            description: "The actual CPU usage of the cluster exceeds 50%. The current CPU usage of the cluster is {{ printf \"%.2f\" $value }}%".
  2. Access the Prometheus web page and choose Alerts. On the displayed page, check whether the alarm rules are triggered or take effect.
  3. The Prometheus add-on automatically pushes alerts to the Alertmanager. If you want to configure the alert recipient, you can configure the key named alertmanager in the monitoring namespace. For details, see the Alertmanager document at https://prometheus.io/docs/alerting/latest/configuration/.
    As shown in the alertmanager-alertmanager StatefulSet YAML file, the alarm data is stored in the pod disk. However, if the pod is restarted, the alarm data will be lost. If you want to persistently store the data, create a PVC and mount it to the pod, and modify the CR of the Alertmanager.
