- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Cluster Monitoring
On the Clusters tab, you can view the monitoring data of each cluster from multiple dimensions, as described in Resource Overview,Top Resource Consumption Statistics, and Data Plane Monitoring.
Navigation Path
- In the navigation pane on the left, choose Monitoring Center. Then click the Clusters tab.
Resource Overview
Resource Overview displays the percentages of abnormal resources in workloads and pods and the total number of namespaces.
CCE collects statistics on top 5 Deployments, StatefulSets, and pods by CPU and memory usages, helping you identify workloads with high resource consumption. To view all data, click the Workloads or Pods tab.
Monitoring metrics
- CPU Usage
Workload CPU usage = Average CPU usage in each pod of the workload
Pod CPU usage = CPU cores used by a pod/CPU limits of service containers
- Memory Usage
Workload memory usage = Average memory usage in each pod of the workload
Pod memory usage = Memory used by a pod/Sum of workload container memory limits
By default, resource usages are collected from each dimension in the last hour, last 8 hours, and last 24 hours. To view more monitoring data, click View All Metrics to access the Dashboard page. For details, see Using Dashboard.
You can hover over a chart to view the monitoring data in each minute.
- Pod Status and Quantity: real-time status and number of pods in a cluster.
- Trend of Total Pod Restarts: the total number of pod restarts in the cluster in the last 5 minutes.
