- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Show all
Connecting to a Cluster Using CloudShell
You can use CloudShell to connect a cluster.
Permissions
When using kubectl in CloudShell, the kubectl permissions are determined by the login user.
Using CloudShell
CloudShell is a web shell used to manage and maintain cloud resources. CCE allows you to use CloudShell to connect to clusters and use kubectl in CloudShell to access clusters (by clicking the command line tool icon in Figure 1).
- The kubectl certificate in CloudShell is valid for one day. You can reset the validity period by accessing CloudShell from the CCE console.
- CloudShell can be used only after CoreDNS is installed in a cluster.
- CloudShell cannot be used by delegated accounts or in sub-projects.
