Connecting to a Cluster Using an X.509 Certificate
This section describes how to obtain the cluster certificate from the console and use it to access Kubernetes clusters.
 - On the Overview page, locate the Connection Info area, and click Download next to X.509 certificate.
     Figure 1 Downloading a cluster certificate
      - In the Obtain Certificate dialog box displayed, select the certificate expiration time and download the X.509 certificate of the cluster as prompted.
      - The downloaded certificate contains three files: client.key, client.crt, and ca.crt. Keep these files secure.
 - Certificates are not required for mutual access between containers in a cluster.
 - Call native Kubernetes APIs using the cluster certificate.
For example, run the curl command to call an API to obtain the pod information. In the following information, *****:5443 indicates the private IP address or EIP and port number of the API server in the cluster.
curl --cacert ./ca.crt --cert ./client.crt --key ./client.key https://*****:5443/api/v1/namespaces/default/pods/
For more cluster APIs, see Kubernetes APIs.
