- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Configuring SFS Turbo Mount Options
This section describes how to configure SFS Turbo volume mount options. For SFS Turbo, you can only set mount options in a PV and bind the PV by creating a PVC.
CCE Autopilot presets the options described in Table 1 for mounting SFS Turbo volumes.
Parameter |
Value |
Description |
vers |
3 |
File system version. Currently, only NFS v3 is supported. Value: 3 |
nolock |
Leave it blank. |
Whether to lock files on the server using the NLM protocol. If nolock is selected, the lock is valid for applications on one host. For applications on another host, the lock is invalid. |
timeo |
600 |
Waiting time before the NFS client retransmits a request. The unit is 0.1 seconds. Recommended value: 600 |
hard/soft |
Leave it blank. |
Mount mode.
The default value is hard. |
You can set other mount options if needed. For details, see Mounting an NFS File System to ECSs (Linux).
Configuring Mount Options in a PV
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in SFS Turbo Mount Options.
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Configure mount options in a PV. The following is an example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner name: pv-sfsturbo # PV name. spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for SFS Turbo. capacity: storage: 500Gi # SFS Turbo volume capacity. csi: driver: sfsturbo.csi.everest.io # Dependent storage driver for the mounting. fsType: nfs volumeHandle: {your_volume_id} # SFS Turbo volume ID. volumeAttributes: everest.io/share-export-location: {your_location} # Shared path of the SFS Turbo volume. everest.io/enterprise-project-id: {your_project_id} # Project ID of the SFS Turbo volume. storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner persistentVolumeReclaimPolicy: Retain # Reclaim policy. storageClassName: csi-sfsturbo # Storage class name of the SFS Turbo volume. mountOptions: # Mount options. - vers=3 - nolock - timeo=600 - hard
- After a PV is created, you can create a PVC and bind it to the PV, and then mount the PV to the container in the workload. For details, see Using an Existing SFS Turbo File System Through a Static PV.
- Check whether the mount options take effect.
In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can run the mount -l command to check whether the mount options take effect.
- View the pod to which the SFS Turbo volume has been mounted. In this example, the workload name is web-sfsturbo.
kubectl get pod | grep web-sfsturbo
Command output:
web-sfsturbo-*** 1/1 Running 0 23m
- Run the following command to check the mount options (web-sfsturbo-*** is an example pod):
kubectl exec -it web-sfsturbo-*** -- mount -l | grep nfs
If the mounting information in the command output is consistent with the configured mount options, the mount options have been configured.
<Your mount path> on /data type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,noresvport,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=**.**.**.**,mountvers=3,mountport=20048,mountproto=tcp,local_lock=all,addr=**.**.**.**)
