CCE Advanced HPA
CCE Advanced HPA (cce-hpa-controller) is an in-house add-on, which can be used to flexibly scale in or out Deployments based on metrics such as CPU usage and memory usage.
Main Functions
- Scaling can be performed based on the percentage of the current number of pods.
- The minimum scaling step can be set.
- Different scaling operations can be performed based on the actual metric values.
- Kubernetes Metrics Server: provides basic resource usage metrics, such as container CPU and memory usage. It is supported by all cluster versions.
- Creating an HPA Policy Using Custom Metrics: Custom metrics need to be aggregated to the Kubernetes API server for auto scaling.
Installing the Add-on
- In the navigation pane, choose Add-ons. On the right of the displayed page, find the CCE Cluster Autoscaler add-on and click Install.
- On the Install Add-on page, configure the specifications.
Table 1 CCE Advanced HPA specifications Parameter
Pods
Number of pods for the add-on.
High availability is not possible if there is only one pod. If an error occurs on the node where the pod runs, the add-on will fail.
CPU and memory quotas of the container allowed for the selected add-on specifications.
You can adjust the container specifications of an add-on instance as required.
- Click Install.
Components
Component |
Description |
Resource Type |
customedhpa-controller |
CCE auto scaling component, which scales in or out Deployments based on metrics such as CPU usage and memory usage |
Deployment |
