Updated on 2025-11-13 GMT+08:00
Configuring a Time AS Policy
This section describes how to configure a time AS policy. You can configure a time policy to periodically scale instances. This frees you from repeatedly adjusting resources to keep up with service changes and peak pressures, helping you reduce resources and labor costs.
CAE instance scaling is calculated by current and expected metrics.
Expected instances = ceil [Current instances * (Current metrics/Expected metrics)] (ceil is rounded up.)
There is an error tolerance of 10% to prevent frequent fluctuation of instance quantity, so there is no scaling when Current metrics/Expected metric ranges from 0.9 to 1.1.
Application Scenario
This policy is useful for periodic resource usage, mainly in industries such as securities, healthcare, and education.
  1. Log in to CAE.
  2. Choose Component Configurations.
  3. Select the target component from the component drop-down list in the upper part of the page.
  4. Click Edit in the AS Policies module.
  5. Click to enable the AS policy.
  6. Select Time and configure the policy by referring to Table 1.
    Table 1 Configuring a time policy
    Max. Instances
    Max. number of instances that can be reached during scale-out.
    Value range: 1 to 99.
    Max. Instances must be greater than Min Instances.
    Min Instances
    Min number of instances that can be reached during scale-in.
    Trigger Cycle
    The policy is expected to be executed at a specified interval. Value: Every day, Every day, or Monthly.
    Trigger Time in a Day
    This parameter is mandatory when Trigger Cycle is set to Every day.
    Configure the policy triggered every day.
    For example, the number of instances remains 3 after 18:00 every day.
    Click Add Trigger Time to add more time policies.
    Trigger Time in a Week
    This parameter is mandatory when Trigger Cycle is set to Every week.
    Configure the policy triggered every week.
    For example, the number of instances remains 4 after 08:00 on every Monday.
    Trigger Time in a Month
    This parameter is mandatory when Trigger Cycle is set to Monthly.
    Configure the policy triggered every month.
    For example, the number of instances remains 4 after 06:00 on the fifth day of each month.
    You can configure time segments to control instance scaling.
    For example, set Trigger Cycle to Every day, and set From 18:00 and Instances 3, and From 00:00 and Instances 1. The system keeps 1 instance from 00:00 to 18:00, and 3 instances from 18:00 to 00:00 every day.
    Figure 1 Configuring a time policy
  7. Click OK.
  8. Click Activate Settings in the upper part of the page. In the dialog box displayed on the right, confirm the configurations and click OK for the configurations to take effect.
