Help Center/ API Gateway/ User Guide/ Managing APIs/ API Design File Extension Definitions/ x-apigateway-backend.httpVpcMemberGroupEndpoints.memberGroupUrlInfos
Updated on 2025-12-03 GMT+08:00
Meaning: HTTP VPC backend service definition. It is restricted. To use it, submit a service ticket.
Scope of effect: x-apigateway-backend
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      parameters:
        - name: "X-Auth-Token"
          description: "Authentication token"
          type: "string"
          in: "header"
          required: true
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "HTTP-VPC-MEMBER-GROUP"
        httpVpcMemberGroupEndpoints:
          memberGroupUrlInfos:
            - name: "xxxxx"
              scheme: "http"
              method: "GET"
              path: "/users"
          enableClientSsl: false
          enableSmChannel: false
          retryCount: 0
          timeout: 5000
Table 1 Parameter description
Mandatory
Type
scheme
Yes
String
Backend request protocol. HTTP and HTTPS are supported.
method
Yes
String
Backend request method. The options include GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH, and ANY.
path
Yes
String
Request address, which can contain request parameters enclosed with braces ({}). For example, /getUserInfo/{userId}. Special characters, such as asterisks (*), slashes (/), percent signs (%), hyphens (-), underscores (_), and periods (.), are allowed. It can contain a maximum of 512 characters and must comply with URI specifications.
Environment variables are supported. Each must start with a letter and can consist of 3 to 32 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed.
name
Yes
String
Name of the VPC channel's backend server group. It can contain 3 to 64 characters, starting with a letter. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. Chinese characters must be in UTF-8 or Unicode format.
