Help Center/
API Gateway/
User Guide/
Managing APIs/
API Design File Extension Definitions/
x-apigateway-result-failure-sample
Updated on 2025-01-10 GMT+08:00
Meaning: Example of a failed response.
Scope of effect: Operation Responses
Example:
paths:
get:
responses:
default:
x-apigateway-result-failure-sample: fail
Parent topic: API Design File Extension Definitions
