Updated on 2025-12-03 GMT+08:00
x-apigateway-authorizer
Meaning: Custom authorizer.
Scope of effect: Security Scheme Object
Example:
x-apigateway-authorizer:
      auth_downgrade_enabled: false
      authorizer_alias_uri: ''
      authorizer_type: FUNC
      authorizer_uri: >-
        urn:fss:region:73d69ae0cfcf460190522d**********:function:default:DSFA
      authorizer_version: latest
      identities:
          validation: ''
      need_body: false
      network_type: V2
      retry_attempts: 0
      timeout: 5000
      ttl: 0
      type: FRONTEND
Table 1 Parameter description
Mandatory
Type
authorizer_type
Yes
String
Custom authorizer type: FUNC.
authorizer_uri
Yes
String
Function URN.
No
Boolean
Whether to enable the relaxed mode. The default value is false.
No
String
Function alias address.
If both the alias and version are specified, the version will be ignored and only the alias will be used.
authorizer_version
No
String
Function version.
Maximum length: 64 characters.
need_body
No
Boolean
Indicates whether to send the body.
identities
No
Array of Identity objects
Identity source.
network_type
No
String
Function network architecture:
  • V1: non-VPC
  • V2: VPC
Default value: V1.
retry_attempts
No
Number
Number of retries.
timeout
No
Number
Timeout.
ttl
No
Number
Cache TTL.
type
Yes
String
Custom authorizer type.
  • FRONTEND
  • BACKEND
Table 2 Identity
Mandatory
Type
name
Yes
String
Parameter name.
location
Yes
String
Parameter location.
validation
No
String
Parameter verification expression. The default value is null, indicating that no verification is performed.
