Proxy Mirror
APIG mirrors source backend requests to images for traffic analysis and statistics without affecting online services.
If your gateway does not support this policy, submit a service ticket to upgrade the gateway to the latest version.
- An API can be bound with only one proxy mirror policy for a given environment, but each proxy mirror policy can be bound to multiple APIs.
- The response to the image request will be ignored.
- The body size of an image request is defaulted to 12 MB and can be configured via the parameter request_body_size. A larger request body size indicates greater performance loss. Exercise caution when performing this operation.
- Not supported for APIs with a Mock backend.
- Policies are independent of APIs. A policy takes effect for an API only after they are bound to each other. When binding a policy to an API, you must specify an environment where the API has been published. The policy takes effect for the API only in the specified environment.
- After you bind a policy to an API, unbind the policy from the API, or update the policy, you do not need to publish the API again.
- Taking an API offline does not affect the policies bound to it. The policies are still bound to the API if the API is published again.
- Policies that have been bound to APIs cannot be deleted.
Creating a Proxy Mirror Policy
- Go to the APIG console.
- Select a dedicated gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Policies.
- On the Policies tab, click Create Policy.
- On the Select Policy Type page, select Proxy Mirror in the Plug-ins area.
- Set the policy information based on the following table.
Table 1 Proxy mirror parameters Parameter
Name
Enter a policy name. Using naming rules facilitates future search.
It can contain 3 to 255 characters and must start with a letter. Only letters, digits, and underscores (_) are allowed.
Type
Fixed as Proxy Mirror.
Description about the plug-in. Enter 1 to 255 characters.
Policy Content
Content of the plug-in, which can be configured in a form or using a script.
Protocol
The image request protocol. It must be the same as the user's image service protocol.
Image Address
The image service address, which consists of the IP address/domain name and port number. Max: 255 characters. Format: Host name:Port number. Example: xxx.xxx.xxx:7443. If the port number is not specified, the default HTTPS port 443 or the default HTTP port 80 is used.
Image URI
URI for HTTP/HTTPS image requests. Max. 512 characters, including special characters (*%-_.). Defaults to the original path of the bound API if not specified.
Concatenation
Specifies how to concatenate the image request path.
- Replace: Uses the specified image request path.
- Prefix: Combines the specified image request path and the source request URI.
Sampling Ratio
Sampling ratio of image requests. Range: 0.00001–1. Default: 1 (full sampling)
For example, if there are 1,000 API requests and the sampling ratio is 0.1, 100 requests will be sampled.
Timeout (ms)
Image request timeout. Unit: ms. Default: 5,000 ms.
Mirror Request Body
Mirrors the body of client requests. Enabled by default.
- Click OK.
To clone this policy, click Clone in the Operation column. The name of a cloned policy cannot be the same as that of any existing policy.
- After the policy is created, perform the operations described in Binding the Policy to APIs to apply the policy for the API.
Example Script
"protocol": "HTTPS",
"host": "X.X.X.X",
"sample_ratio": 1,
"timeout": 5000,
"mirror_request_body_enabled": true,
"path": "/ab",
"path_concat_mode": "replace"
- Click the policy name to go to the policy details page.
- Select an environment and click Select APIs.
- Select the API group, environment, and required APIs.
APIs can be filtered by API name or tag. The tag is defined during API creation.
- Click OK.
- If an API no longer needs this policy, click Unbind in the row that contains the API.
- If there are multiple APIs that no longer need this policy, select these APIs, and click Unbind above the API list. You can unbind a policy from a maximum of 1000 APIs at a time.
