Gang
Gang scheduling is a scheduling algorithm that schedules correlated processes or threads to run simultaneously on different processors. It meets the scheduling requirements of "All or nothing" in the scheduling process and avoids the waste of cluster resources caused by arbitrary scheduling of pods. Gang is mainly used in scenarios that require multi-process collaboration, such as AI and big data scenarios. Gang scheduling effectively resolves pain points such as deadlocks in distributed training jobs, thereby significantly improving the utilization of cluster resources.
How It Works
The Gang scheduling policy is one of the core scheduling algorithms of Volcano. It meets the scheduling requirements of "All or nothing" in the scheduling process and avoids the waste of cluster resources caused by arbitrary scheduling of pods. The Gang scheduler algorithm checks whether the number of scheduled pods in a job meets the minimum requirements for running the job. If yes, all pods in the job will be scheduled. If no, the pods will not be scheduled.
The Gang scheduling algorithm based on container groups is well suitable for scenarios where multi-process collaboration is required. AI scenarios typically involve complex processes. Data ingestion, data analysts, data splitting, trainers, serving, and logging which require a group of containers to work together are suitable for container-based Gang scheduling. Multi-thread parallel computing communication scenarios under MPI computing framework are also suitable for Gang scheduling because master and slave processes need to work together. Containers in a pod group are highly correlated, and there may be resource contention. The overall scheduling allocation can effectively resolve deadlocks. If cluster resources are insufficient, Gang scheduling can significantly improve the utilization of cluster resources.
Configuring Gang
After Volcano is installed, you can enable or disable Gang scheduling on the Scheduling page. This function is enabled by default.
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. Choose Settings in the navigation pane and click the Scheduling tab.
  3. In the AI task performance enhanced scheduling pane, select whether to enable Gang.
    This function helps you enhance the service throughput of the cluster and improve service running performance.
  4. Click Confirm.
  5. After the configuration, use Gang scheduling in workloads or Volcano jobs.
    • Create a workload using Gang scheduling.
      1. Create a pod group and specify minMember and minResources as follows:
        apiVersion: scheduling.volcano.sh/v1beta1
        kind: PodGroup
          minMember: 3
          minResources:
            cpu: 3
            memory: 3Gi
        • minMember: specifies the minimum requirement on the number of pods for running a workload. When the number of pods in the current pod group meets the requirement, these pods can be centrally scheduled.
        • minResources: specifies the minimum requirement on resources for running a workload. When the available resources in a cluster meet the requirement, the group of pods can be centrally scheduled.
      2. When creating a workload, use schedulerName to specify Volcano Scheduler and annotation to specify the pod group in which Volcano Scheduler runs.
        apiVersion: apps/v1
        kind: Deployment
          labels:
            app: podgroup-test
          replicas: 6
          selector:
            matchLabels:
              app: podgroup-test
          template:
              annotations:
                scheduling.k8s.io/group-name: pg-test1
              labels:
                app: podgroup-test
              schedulerName: volcano
              containers:
              - name: test
                image: busybox
                imagePullPolicy: IfNotPresent
                command: ['sh', '-c', 'echo "Hello, Kubernetes!" && sleep 3600']
                resources:
                  requests:
                    cpu: 500m
                  limits:
                    cpu: 500m
        • schedulerName: Set this parameter to volcano, indicating that Volcano will be used to schedule pods for the workload.
        • scheduling.k8s.io/group-name: specifies the pod group created in the previous step, for example, pg-test1.
    • Create a Volcano job using Gang scheduling.
      When creating a Volcano job, you only need to configure minAvailable and set schedulerName to volcano. Volcano Scheduler will automatically create a pod group and manage it. The following shows an example:
      apiVersion: batch.volcano.sh/v1alpha1
      kind: Job
        minAvailable: 2
        tasks:
          - replicas: 4
            template:
                containers:
                  - image: alpine
                    command: ["/bin/sh", "-c", "sleep 1000"]
                    resources:
                      requests:
                        cpu: "1"
                restartPolicy: OnFailure
