Using kubectl to Create a LoadBalancer Ingress
This section uses an Nginx workload as an example to describe how to create a LoadBalancer ingress using kubectl.
Ingress Description of networking.k8s.io/v1
In CCE clusters of v1.23 or later, the ingress version is switched to networking.k8s.io/v1.
Compared with v1beta1, v1 has the following differences in parameters:
  • The ingress type is changed from kubernetes.io/ingress.class in annotations to spec.ingressClassName.
  • The format of backend is changed.
  • The pathType parameter must be specified for each path. The options are as follows:
    • ImplementationSpecific: The matching method depends on Ingress Controller. The matching method defined by ingress.beta.kubernetes.io/url-match-mode is used in CCE, which is the same as v1beta1.
    • Exact: exact matching of the URL, which is case-sensitive.
    • Prefix: matching based on the URL prefix separated by a slash (/). The match is case-sensitive, and elements in the path are matched one by one. A path element refers to a list of labels in the path separated by a slash (/).
Creating an Ingress - Automatically Creating a Load Balancer
The following describes how to run the kubectl command to automatically create a load balancer when creating an ingress.
  1. Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    Starting from cluster v1.23, the ingress version is switched from networking.k8s.io/v1beta1 to networking.k8s.io/v1. For details about the differences between v1 and v1beta1, see Ingress Description of networking.k8s.io/v1.
    Example of a dedicated load balancer (public network access) for clusters of v1.23 or later:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.autocreate:
              "type": "public",
              "bandwidth_name": "cce-bandwidth-******",
              "bandwidth_chargemode": "bandwidth",
              "bandwidth_size": 5,
              "bandwidth_sharetype": "PER",
              "eip_type": "5_bgp",
              "vip_subnet_cidr_id": "*****",
              "vip_address": "**.**.**.**",
              "elb_virsubnet_ids":["*****"],
              "available_zone": [
              "l7_flavor_name": "L7_flavor.elb.s1.small"
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: <your_service_port>  # Replace it with the port number of your target Service.
            property:
      ingressClassName: cce
    Example of a dedicated load balancer (public network access) for clusters of version 1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/ingress.class: cce
              "type": "public",
              "available_zone": [
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: <your_service_port>  # Replace it with the port number of your target Service.
            property:
    Table 1 Key parameters
    Mandatory
    Type
    Yes
    String
    Select a proper load balancer type.
    • performance: dedicated load balancer..
    Yes
    (only for clusters of v1.21 or earlier)
    String
    cce: A proprietary LoadBalancer ingress is used.
    This parameter is mandatory when an ingress is created by calling the API.
    ingressClassName
    Yes
    (only for clusters of v1.23 or later)
    String
    Yes
    String
    This parameter indicates the external port registered with the address of the LoadBalancer Service.
    Supported range: 1 to 65535
    Some ports are high-risk ports and are blocked by default, for example, port 21.
    kubernetes.io/elb.subnet-id
    None
    String
    ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
    • Mandatory when a cluster of v1.11.7-r0 or earlier is to be automatically created.
    • Optional for clusters later than v1.11.7-r0. It is left blank by default.
    Yes
    elb.autocreate object
    Whether to automatically create a load balancer associated with an ingress. For details about the field description, see Table 2.
    Example
    • If a public network load balancer will be automatically created, set this parameter to the following value:
      {"type":"public","bandwidth_name":"cce-bandwidth-******","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}
    • If a private network load balancer will be automatically created, set this parameter to the following value:
      {"type":"inner","name":"A-location-d-test"}
    host
    No
    String
    Domain name for accessing the Service. By default, this parameter is left blank, and the domain name needs to be fully matched. Ensure that the domain name has been registered and archived. Once a domain name rule is configured, you must use the domain name for access.
    path
    Yes
    String
    User-defined route path. All external access requests must match host and path.
    The access path added here must exist in the backend application. Otherwise, the forwarding fails.
    For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
    No
    String
    Route matching policy.
    Default: STARTS_WITH (prefix match)
    Options:
    • EQUAL_TO: exact match
    • STARTS_WITH: prefix match
    • REGEX: regular expression match
    pathType
    Yes
    String
    Path type. This field is supported only by clusters of v1.23 or later.
    • ImplementationSpecific: The matching method depends on Ingress Controller. The matching method defined by ingress.beta.kubernetes.io/url-match-mode is used in CCE.
    • Prefix: prefix matching, which is case-sensitive. With this method, the URL path is separated into multiple elements by slashes (/) and the elements are matched one by one. If each element in the URL matches the path, the subpaths of the URL can be routed normally.
      • During prefix matching, each element must be exactly matched. If the last element of the URL is the substring of the last element in the request path, no matching is performed. For example, /foo/bar matches /foo/bar/baz but does not match /foo/barbaz.
      • When elements are separated by slashes (/), if the URL or request path ends with a slash (/), the slash (/) at the end is ignored. For example, /foo/bar matches /foo/bar/.
    See examples of ingress path matching.
    Table 2 elb.autocreate data structure
    Mandatory
    Type
    name
    No
    String
    Name of the automatically created load balancer.
    The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
    Default: cce-lb+service.UID
    type
    No
    String
    Network type of the load balancer.
    • public: public network load balancer
    • inner: private network load balancer
    Default: inner
    bandwidth_name
    Yes for public network load balancers
    String
    Bandwidth name. The default value is cce-bandwidth-******.
    No
    String
    Bandwidth mode.
    • bandwidth: billed by bandwidth
    • traffic: billed by traffic
    Default: bandwidth
    bandwidth_size
    Integer
    Bandwidth size. The default value is 1 to 2000 Mbit/s. Configure this parameter based on the bandwidth range allowed in your region.
    The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
    • The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
    • The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1000 Mbit/s.
    • The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1000 Mbit/s.
    bandwidth_sharetype
    String
    Bandwidth sharing mode.
    • PER: dedicated bandwidth
    eip_type
    String
    EIP type.
    • 5_bgp: dynamic BGP
    The specific type varies with regions. For details, see the EIP console.
    vip_subnet_cidr_id
    No
    String
    Subnet where a load balancer is located. The subnet must belong to the VPC where the cluster resides.
    If this parameter is not specified, the ELB load balancer and the cluster are in the same subnet.
    This field can be specified only for clusters of v1.21 or later.
    vip_address
    No
    String
    Private IP address of the load balancer. Only IPv4 addresses are supported.
    The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block.
    This parameter is available only in clusters of v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions.
    available_zone
    Yes
    Array of strings
    AZ where the load balancer is located.
    This parameter is available only for dedicated load balancers.
    l4_flavor_name
    Yes
    String
    Flavor name of the layer-4 load balancer.
    l7_flavor_name
    No
    String
    Flavor name of the layer-7 load balancer.
    This parameter is available only for dedicated load balancers. The value of this parameter must be the same as that of l4_flavor_name, that is, both are elastic specifications or fixed specifications.
    elb_virsubnet_ids
    No
    Array of strings
    Subnet where the backend server of the load balancer is located. If this parameter is left blank, the default cluster subnet is used. Load balancers occupy different number of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters and nodes) as the load balancer CIDR block.
    Example:
    "elb_virsubnet_ids": [
       "14567f27-8ae4-42b8-ae47-9f847a4690dd"
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created.
    ingress/ingress-test created
    kubectl get ingress
    If information similar to the following is displayed, the ingress has been created and the workload is accessible.
    NAME             HOSTS     ADDRESS          PORTS   AGE
    ingress-test     *         121.**.**.**     80      10s
  4. Enter http://121.**.**.**:80 in the address box of the browser to access the workload (for example, Nginx workload).
    121.**.**.** indicates the IP address of the unified load balancer.
Creating an Ingress - Interconnecting with an Existing Load Balancer
CCE allows you to connect to an existing load balancer when creating an ingress.
  • Existing dedicated load balancers must be the application type (HTTP/HTTPS) supporting private networks (with a private IP).
If the cluster version is 1.23 or later, the YAML file configuration is as follows:
kind: Ingress
  annotations:
    kubernetes.io/elb.id: <your_elb_id>  # Replace it with the ID of your existing load balancer.
    kubernetes.io/elb.ip: <your_elb_ip>  # Replace it with the IP of your existing load balancer.
    kubernetes.io/elb.class: performance  # Load balancer type
  rules:
  - host: ''
    http:
      paths:
      - path: '/'
        backend:
          service:
            port:
              number: 8080             # Replace 8080 with the port number of your target Service.
        property:
If the cluster version is 1.21 or earlier, the YAML file configuration is as follows:
kind: Ingress
  annotations:
  rules:
  - host: ''
    http:
      paths:
      - path: '/'
        backend:
          servicePort: 80
        property:
Table 3 Key parameters
Mandatory
Type
Yes
String
ID of a load balancer. The value can contain 1 to 100 characters.
How to obtain:
On the management console, click Service List, and choose Networking > Elastic Load Balance. Click the name of the target load balancer. On the Summary tab page, find and copy the ID.
No
String
Service address of a load balancer. The value can be the public IP address of a public network load balancer or the private IP address of a private network load balancer.
Yes
String
Load balancer type.
