quarter
This function is used to return the quarter of a date. The value ranges from 1 to 4.
Syntax
quarter(string date)
Parameters
Parameter |
Mandatory |
Type |
Description |
date |
Yes |
DATE or STRING |
Date that needs to be processed
The following formats are supported:
Return Values
The return value is of the INT type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
Example Code
The value 3 is returned.
select quarter('2023-08-16 10:54:00');
select quarter('2023-08-16');
The value NULL is returned.
select quarter(null);
