next_day
This function is used to return the date closest to day_of_week after start_date.
Syntax
next_day(string start_date, string day_of_week)
Parameters
Parameter |
Mandatory |
Type |
Description |
start_date |
Yes |
DATE or STRING |
Date that needs to be processed If the value is of the STRING type, the value must contain at least yyyy-mm-dd and cannot contain redundant strings.
The following formats are supported:
day_of_week |
Yes |
STRING |
One day of a week, either the first two or three letters of the word, or the full name of the word for that day. For example, TU indicates Tuesday. |
Return Values
The return value is of the DATE type, in the yyyy-mm-dd format.
![](https://support.huaweicloud.com/intl/en-us/sqlref-spark-dli/public_sys-resources/note_3.0-en-us.png)
- If the value of start_date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of start_date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of start_date is NULL, NULL is returned.
- If the value of day_of_week is NULL, NULL is returned.
Example Code
The value 2023-08-22 is returned.
select next_day('2023-08-16','TU');
select next_day('2023-08-16 10:54:00','TU');
The value 2023-08-23 is returned.
select next_day('2023-08-16 10:54:00','WE');
The value NULL is returned.
select next_day('20230816','TU');
select next_day('20230816 20:00:00',null);
