Help Center/ Data Lake Insight/ Spark SQL Syntax Reference/ Tables/ Modifying a Table/ Enabling or Disabling Multiversion Backup
Updated on 2024-07-04 GMT+08:00
Function
DLI controls multiple versions of backup data for restoration. After the multiversion function is enabled, the system automatically backs up table data when you delete or modify the data using insert overwrite or truncate, and retains the data for a certain period. You can quickly restore data within the retention period. For details about the syntax related to the multiversion function, see Backing Up and Restoring Data of Multiple Versions.
Currently, the multiversion function supports only OBS tables created using the Hive syntax. For details about the syntax for creating a table, see Creating an OBS Table Using the Hive Syntax.
Syntax
  • Enable the multiversion function.
    ALTER TABLE [db_name.]table_name
    SET TBLPROPERTIES ("dli.multi.version.enable"="true");
  • Disable the multiversion function.
    UNSET TBLPROPERTIES ("dli.multi.version.enable");
    After multiversion is enabled, data of different versions is automatically stored in the OBS storage directory when insert overwrite or truncate is executed. After multiversion is disabled, run the following statement to restore the multiversion backup data directory:
    RESTORE TABLE [db_name.]table_name TO initial layout;
Keywords
  • SET TBLPROPERTIES: Used to set table properties and enable multiversion.
  • UNSET TBLPROPERTIES: Used to unset table properties and disable multiversion.
Parameters
Table 1 Parameters
db_name
Database name that contains letters, digits, and underscores (_). It cannot contain only digits or start with an underscore (_).
table_name
Table name
Precautions
Example
  • Modify the test_table table to enable multiversion.
    ALTER TABLE test_table
  • Modify the test_table table to disable multiversion.
    Restore the multiversion backup data directory.
    RESTORE TABLE test_table TO initial layout;
