Updated on 2025-08-06 GMT+08:00
Restoring Multi-Versioning Backup Data (Deprecated, Not Recommended)
Function
The multi-versioning feature is to be deprecated and is not recommended. Recommended functions: Hudi multi-versioning cleanup and Hudi archive.
After the multiversion function is enabled, you can run the RESTORE TABLE statement to restore a table or partition of a specified version. For details about the syntax for enabling or disabling the multiversion function, see Enabling or Disabling Data Multi-Versioning (Deprecated, Not Recommended).
Currently, the multiversion function supports only OBS tables created using the Hive syntax. For details about the syntax for creating a table, see Creating an OBS Table Using the Hive Syntax.
Syntax
  • Restore the non-partitioned table data to the backup data of a specified version.
    RESTORE TABLE [db_name.]table_name TO VERSION 'version_id';
  • Restore the data of a single partition in a partitioned table to the backup data of a specified version.
    RESTORE TABLE [db_name.]table_name PARTITION (column = value, ...) TO VERSION 'version_id';
Keywords
Parameters
Table 1 Parameters
db_name
Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_).
table_name
Table name
column
Partition column name
value
Value corresponding to the partition column name
version_id
Target version of the backup data to be restored You can run the SHOW HISTORY command to obtain the version number. For details, see Viewing Multi-Versioning Backup Data (Deprecated, Not Recommended).
Precautions
Example
  • Restore the data in non-partitioned table test_table to version 20210930.
    RESTORE TABLE test_table TO VERSION '20210930';
  • Restore the data of partition dt in partitioned table test_table to version 20210930.
    RESTORE TABLE test_table PARTITION (dt='2021-07-27') TO VERSION '20210930';
