Creating a DLI Table and Associating It with CSS
Function
This statement is used to create a DLI table and associate it with an existing CSS table.
In Spark cross-source development scenarios, there is a risk of password leakage if datasource authentication information is directly configured. You are advised to use the datasource authentication provided by DLI.
For details about datasource authentication, see Introduction to Datasource Authentication.
Before creating a DLI table and associating it with CSS, you need to create a datasource connection. For operations on the management console, see Enhanced Datasource Connections.
Syntax
1 2 3 4 5 6 7 8 9 10 11 12 | CREATE TABLE [IF NOT EXISTS] TABLE_NAME( FIELDNAME1 FIELDTYPE1, FIELDNAME2 FIELDTYPE2) USING CSS OPTIONS ( 'es.nodes'='xx', 'resource'='type_path_in_CSS', 'pushdown'='true', 'strict'='false', 'batch.size.entries'= '1000', 'batch.size.bytes'= '1mb', 'es.nodes.wan.only' = 'true', 'es.mapping.id' = 'FIELDNAME'); |
Keywords
Parameter | Description |
es.nodes | Create a datasource connection before you can obtain this CSS connection address. For operations on the management console, see Enhanced Datasource Connections. If you have created an enhanced datasource connection, you can use the internal IP address provided by CSS. The format is IP1:PORT1,IP2:PORT2. |
resource | The resource is used to specify the CSS datasource connection name. You can use /index/type to specify the resource location (for easier understanding, the index can be seen as database and type as table). NOTE:
pushdown | Indicates whether the press function of CSS is enabled. The default value is set to true. If there are a large number of I/O transfer tables, the pushdown can be enabled to reduce I/Os when the where filtering conditions are met. |
strict | Indicates whether the CSS pushdown is strict. The default value is set to false. In exact match scenarios, more I/Os are reduced than pushdown. |
batch.size.entries | Maximum number of entries that can be inserted to a batch processing. The default value is 1000. If the size of a single data record is so large that the number of data records in the bulk storage reaches the upper limit of the data amount of a single batch processing, the system stops storing data and submits the data based on the batch.size.bytes. |
batch.size.bytes | Maximum amount of data in a single batch processing. The default value is 1 MB. If the size of a single data record is so small that the number of data records in the bulk storage reaches the upper limit of the data amount of a single batch processing, the system stops storing data and submits the data based on the batch.size.entries. |
es.nodes.wan.only | Indicates whether to access the Elasticsearch node using only the domain name. The default value is false. If the original internal IP address provided by CSS is used as the es.nodes, you do not need to set this parameter or set it to false. |
es.mapping.id | Specifies a field whose value is used as the document ID in the Elasticsearch node. NOTE:
es.net.ssl | Whether to connect to the secure CSS cluster. The default value is false. |
es.certificate.name | Name of the datasource authentication used to connect to the secure CSS cluster. For details about how to create datasource authentication, see Datasource Authentication in the Data Lake Insight User Guide. |
batch.size.entries and batch.size.bytes limit the number of data records and data volume respectively.
Example
1 2 3 4 5 6 7 8 | CREATE TABLE IF NOT EXISTS dli_to_css (doc_id String, name string, age int) USING CSS OPTIONS ( 'es.nodes' ='to-css-1174404703-LzwpJEyx.datasource.com:9200', 'resource' ='/dli_index/dli_type', 'pushdown' ='false', 'strict' ='true', 'es.nodes.wan.only' ='true', 'es.mapping.id' ='doc_id'); |
