Help Center/ Data Lake Insight/ Spark SQL Syntax Reference/ Datasource Connections/ Creating a Datasource Connection with an OpenTSDB Table/ Querying an OpenTSDB Table
Updated on 2024-07-04 GMT+08:00
This SELECT command is used to query data in an OpenTSDB table.
- If no metric exists in OpenTSDB, an error will be reported when the corresponding DLI table is queried.
- If the security mode is enabled, you need to set conf:dli.sql.mrs.opentsdb.ssl.enabled to true when connecting to OpenTSDB.
Syntax
1 | SELECT * FROM table_name LIMIT number; |
Keywords
LIMIT is used to limit the query results. Only INT type is supported by the number parameter.
Precautions
The table to be queried must exist. Otherwise, an error is reported.
Example
Query data in the opentsdb_table table.
1 | SELECT * FROM opentsdb_table limit 100; |
Parent topic: Creating a Datasource Connection with an OpenTSDB Table
