Creating a DLI Table and Associating It with OpenTSDB
Function
Run the CREATE TABLE statement to create the DLI table and associate it with the existing metric in OpenTSDB. This syntax supports the OpenTSDB of CloudTable and MRS.
Before creating a DLI table and associating it with OpenTSDB, you need to create a datasource connection. For operations on the management console, see Enhanced Datasource Connections.
Syntax
        1 2 3 4 5  |
        CREATE TABLE [IF NOT EXISTS] UQUERY_OPENTSDB_TABLE_NAME USING OPENTSDB OPTIONS ( 'host' = 'xx;xx', 'metric' = 'METRIC_NAME', 'tags' = 'TAG1,TAG2');  |
Keywords
        Parameter  |
        Description  |
        host  |
        OpenTSDB IP address. Create a datasource connection before you can obtain this IP address. For operations on the management console, see Enhanced Datasource Connections.
        metric  |
        Name of the metric in OpenTSDB corresponding to the DLI table to be created.  |
        tags  |
        Tags corresponding to the metric. The tags are used for classification, filtering, and quick retrieval. You can set 1 to 8 tags, which are separated by commas (,). The parameter value includes values of all tagKs in the corresponding metric.  |
Precautions
When creating a DLI table, you do not need to specify the timestamp and value fields. The system automatically builds the following fields based on the specified tags. The fields TAG1 and TAG2 are specified by tags.
- TAG1 String
 - TAG2 String
 - timestamp Timestamp
 - value double
Example
        1 2 3 4 5  |
        CREATE table opentsdb_table USING OPENTSDB OPTIONS ( 'host' = 'opentsdb-3xcl8dir15m58z3.cloudtable.com:4242', 'metric' = 'city.temp', 'tags' = 'city,location');  |
