Viewing Table Properties
Function
Check the properties of a table.
Syntax
1 | SHOW TBLPROPERTIES table_name [('property_name')]; |
Keywords
TBLPROPERTIES: This statement allows you to add a key/value property to a table.
Parameters
| Parameter | Description |
| table_name | Table name |
| property_name |
Precautions
property_name is case sensitive. You cannot specify multiple property_name attributes at the same time. Otherwise, an error occurs.
Example
To return the value of property_key1 in the test table, run the following statement:
1 | SHOW TBLPROPERTIES test ('property_key1'); |
