Configuring an IP Address Whitelist for Modifications Allowed by HBase
If the Replication function is enabled for HBase clusters, a protection mechanism for data modification is added on the standby HBase cluster to ensure data consistency between the active and standby clusters. Upon receiving an RPC request for data modification, the standby HBase cluster checks the permission of the user who sends the request (only HBase manage users have the modification permission). Then it checks the validity of the source IP address of the request. Only modification requests from IP addresses in the white list are accepted. The IP address white list is configured by the hbase.replication.allowedIPs item.
Page access: On FusionInsight Manager, choose Cluster > Name of the desired cluster > Services > component > Configurations. Click All Configurations. Enter the parameter name in the search box.
       Parameter  |
       Description  |
       Default Value  |
       hbase.replication.allowedIPs  |
       Allows replication request processing from configured IP addresses only. It supports comma separated regex patterns. Each pattern can be any of the following:
 If this item is empty (default value), the white list contains only the IP address of the RegionServer of the cluster, indicating that only modification requests from the RegionSever of the standby HBase cluster are accepted.  |
       N/A  |
