Clearing Queue Configurations
The system administrator can clear queue configurations on FusionInsight Manager if a queue does not need resources from a resource pool or a resource pool needs to be disassociated from a queue. Clearing queue configurations means that the resource capacity policy of a queue in the resource pool is canceled.
If a queue is to be unbound from a resource pool, you have ensured that the resource pool is not the default resource pool of the queue. For details, see Configuring a Queue.
- Log in to FusionInsight Manager portal.
 - Choose Tenant Resources > Dynamic Resource Plan
 - Set Cluster to the name of the cluster to be operated. In Resource Pool, select the specified resource pool.
 - Locate the row that contains the specified queue in Resource Allocation and click Clear in the Operation column.
 - In Clear Queue Configuration, click OK to clear the queue configurations in the current resource pool.
