Log Downloadind
FusionInsight Manager allows you to export logs generated by all instances of each service role in batches. You do not need to manually log in to a specified node to obtain the logs.
 - Choose O&M > Log > Download.
 - Select a log downloading range:
- Service: Click
 to set a service for Service. - Host: Set the IP address of the host where the service is deployed. You can also click
 to select the host. - Click
 in the upper right corner to select the corresponding Start Date and End Date.
 - Service: Click
 - Click Download.
The downloaded log package contains the topology information of the corresponding start time and end time, facilitating locating.
The topology file is named in the format of topo_<Topology change time>.txt. The file contains the node IP address, node host name, and service instances installed on the node. (The OMS node is identified by Manager:Manager.)
The following shows an example:
192.168.204.124|suse-124|DBService:DBServer;KrbClient:KerberosClient;LdapClient:SlapdClient;LdapServer:SlapdServer;Manager:Manager;meta:meta
