Updated on 2022-12-07 GMT+08:00
Creating a Spark Job
DLI provides fully-managed Spark computing services by allowing you to execute Spark jobs.
On the Overview page, click Create Job in the upper right corner of the Spark Jobs tab or click Create Job in the upper right corner of the Spark Jobs page. The Spark job editing page is displayed.
On the Spark job editing page, a message is displayed, indicating that a temporary DLI data bucket will be created. The created bucket is used to store temporary data generated by DLI, such as job logs and job results. You cannot view job logs if you choose not to create it. The bucket will be created and the default bucket name is used.
If you do not need to create a DLI temporary data bucket and do not want to receive this message, select Do not show again and click Cancel.
  • You have uploaded the dependencies to the corresponding OBS bucket on the Data Management > Package Management page. For details, see Creating a Package.
  • Before creating a Spark job to access other external data sources, such as OpenTSDB, HBase, Kafka, DWS, RDS, CSS, CloudTable, DCS Redis, and DDS MongoDB, you need to create a cross-source connection to enable the network between the job running queue and external data sources.
GUI Description
  • Navigation bar on the left
    On the Spark job creation page, the navigation tree on the left contains the Queues and Packages tab pages.
    Table 1 Description of buttons in the left navigation pane
    No.
    Tab/Button
    Tab/Button Name
    Queues
    Display existing queues.
    2
    Packages
    Display existing packages.
    3
    Templates
    Templates
    Display job templates.
    4
    Create
    Create a queue or a package.
    5
    Refresh
    Refresh the lists of existing queues and packages.
    6
    Search for packages by name.
    On the Packages tab page, enter a package name for search.
  • Job editing window
    In the job editing window, you can set parameters in Fill Form mode or Write API mode.
    The following uses the Fill Form as an example. In Write API mode, refer to the Data Lake Insight API Reference for parameter settings.
    • Select a Queue: For details about the parameters, see Table 2.
      Table 2 Queue parameters
      Queues
      Select the target queue from the drop-down list box.
    • Job Configurations: Refer to Table 3 for details.
      Table 3 Job configuration parameters
      Job Name
      Set a job name.
      Application
      Select the package to be executed. The value can be .jar or .py.
      Main Class
      Enter the name of the main class. When the application type is .jar, the main class name cannot be empty.
      Application Parameters
      User-defined parameters. Separate multiple parameters by Enter.
      These parameters can be replaced by global variables. For example, if you create a global variable batch_num on the Global Configuration > Global Variables page, you can use {{batch_num}} to replace a parameter with this variable after the job is submitted.
      Spark Arguments
      Enter a parameter in the format of key=value. Press Enter to separate multiple key-value pairs.
      These parameters can be replaced by global variables. For example, if you create a global variable custom_class on the Global Configuration > Global Variables page, you can use "spark.sql.catalog"={{custom_class}} to replace a parameter with this variable after the job is submitted.
      The JVM garbage collection algorithm cannot be customized for Spark jobs.
      Job Type
      Type of the Spark image used by a job. This parameter is mandatory when you select a CCE queue. The values are as follows:
      • Basic: Basic images provided by DLI. Select this option for non-AI jobs.
      • AI-enhanced: AI images provided by DLI. Select this option for AI jobs.
      • Image: Custom Spark images. Select an existing image name and version on SWR.
      JAR Package Dependencies
      JAR file on which the Spark job depends. You can enter the JAR package name or the corresponding OBS path. The format is as follows: obs://Bucket name/Folder name/Package name.
      Python File Dependencies
      py-files on which the Spark job depends. You can enter the Python file name or the corresponding OBS path of the Python file. The format is as follows: obs://Bucket name/Folder name/File name.
      Other Dependencies
      Other files on which the Spark job depends. You can enter the name of the dependency file or the corresponding OBS path of the dependency file. The format is as follows: obs://Bucket name/Folder name/File name.
      Group Name
      If you select a group when creating a package, you can select all the packages and files in the group. For details about how to create a package, see Creating a Package.
      Access Metadata
      Whether to access metadata through Spark jobs. .
      Retry upon Failure
      Indicates whether to retry a failed job.
      If you select Yes, you need to set the following parameters:
      Maximum Retries: Maximum number of retry times. The maximum value is 100.
      Advanced Settings
      • Skip
      • Configure
        • Select Dependency Resources: For details about the parameters, see Table 4.
        • Configure Resources: For details about the parameters, see Table 5.
      Table 4 Parameters for selecting dependency resources
      Module Name
      Dependency modules provided by DLI for executing datasource connection jobs. To access different services, you need to select different modules.
      • MRS HBase: sys.datasource.hbase
      • DDS: sys.datasource.mongo
      • MRS OpenTSDB: sys.datasource.opentsdb
      • DWS: sys.datasource.dws
      • RDS MySQL: sys.datasource.rds
      • RDS PostGre: sys.datasource.rds
      • DCS: sys.datasource.redis
      • CSS: sys.datasource.css
      Resource Package
      JAR package on which the Spark job depends.
      Table 5 Resource specification parameters
      Resource Specifications
      Select a resource specification from the drop-down list box. The system provides three resource specifications for you to select. The following configuration items in the resource specifications can be modified:
      • Executor Memory
      • Executor Cores
      • Executors
      • Driver Cores
      • Driver Memory
      If modified, your modified settings of the items are used.
      Executor Memory
      Customize the configuration item based on the selected resource specifications.
      Executor Cores
      Executors
      Driver Cores
      Driver Memory
      Spark job parameter calculation:
      • Number of CUs = Number of driver CPU cores + Number of executors x Number of executor CPU cores
        The cluster management plane and driver use some CU resources. Number of Executors * Number of Executor Cores must be smaller than the number of computing CUs of the queue.
      • Memory = Driver memory + (Number of Executors x Executor memory)
  1. In the Spark job editing window, set related parameters. For details, see the description of the Spark job editing window.
  2. Click Execute in the upper right corner of the Spark job editing window to submit the job. The message "The batch job is submitted." is displayed.
  3. (Optional) Go to the Spark Jobs page to view the status and logs of the submitted Spark job.
